It is currently Thu May 23, 2024 12:27 am
Post new topic  Reply to topic  [ 235 posts ]  Go to page Previous 1 2 3 4 5 616 Next
PostPosted: Sun Feb 25, 2007 4:06 pm
Damn nice car, I've always wanted a Right hand drive car. I like the look and it would confuse the hell out of my friends the first time i'd pull up :P . I think it would be worth the money to import one, Na it would probaly cost more than the car new to ship it here. :lol:
93-Plymouth colt 5-spd 1.5L 2-door stock (for now)
PostPosted: Mon Feb 26, 2007 6:39 pm
4WD badge. Ohhhhhh yeahhh! :D :D :lol:
How hard are those to find. I Would LOVE to have one. :) please.
I found one of these in a junk yard here in St.Louis the cost FREE :lol:
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Mon Feb 26, 2007 6:46 pm
And very nice car.s I know that you know where all jellous.
Adam
05'WRX
 Post subject: oi'm gonna import one.
PostPosted: Wed Feb 28, 2007 1:05 pm
I wanna import one as well. I would drop the 4g63 in it right away.. it would probably register pretty easy. U.S motor and ecu and all the little smog bs.. so lets get a group buy going on these. i know you can rent a big cargo crate for. i'm not sure but if we all went in on it. we could probably fit five or more cars in there. whos down?
PostPosted: Wed Feb 28, 2007 3:13 pm
LOL, you're dreaming. You live in California. It would NOT be an easy thing to do and for the cost of doing it you could buy a base-model CSM, swap a 4G63 into it, AND make it AWD, and have money left over to buy yourself a 3 Musketeers bar.
PostPosted: Wed Feb 28, 2007 4:27 pm
lol damn it.. you just crushed my dreams... i always wanted to import an s13 or 14. but i would love to have that awd mirage. damn damn damn
PostPosted: Tue Mar 06, 2007 9:21 pm
Haha whoa I didn't notice all these replys. Almost 1000 views on this thread, wow :o :lol:
Haha, as well as what the CaptainTonus mentioned above, you have to remember that these cars aren't exactly common over here either. Actually, the amount of C83A's i've seen with my own eyes, I could count on one hand. You'd probably have to live here for a few years if you wanted to find 5 of them :lol:
*Big ear to ear grin* hahaha
PostPosted: Wed Jan 30, 2008 11:01 pm
Mmm haven't updated this in ages...
I've probably posted half this crap in the pics/vids section but here it is again..
Swapped the good interior in, back in March
And attempted to fit some crap into the tiny 4WD boot
Then lowered it on some crap springs, brand new crap shocks, and 17"s
Rear still sat high as a kite even though the springs weren't captive...
Moved the battery to the boot..
Meanwhile, something evil was in the works :lol:
Got some factory rice
Part number is MB726336 if anyone wants to know
Washed the car :lol:
JDM y0 :lol:
More JDM y000
And a genuine Bride bolt in drivers side rail from Japan
Sold the 17"s, and swapped a tidier bumper and filler panel on from my other car
Replaced the 17"s with genuine TE37's 8)
Bought new front discs and pads
And now for the fun part :lol:
Thanks to Patrick from 4G61NZ we had the use of his boss's workshop over a weekend, so we got to work on the engine swap
The n/a beast:
N/A:
61T with TD04L still on, and flywheel, 3" front pipe, evo AFM etc..
My grotty 3.545 diff setup that looks like its just been pulled from the bottom of the ocean..
Parts pile
PSIBRG :wink:
Bye bye n/a!
Flying Borg
All assembled and ready to go in :D
New rings, bearings, block honed, oil galleries and squirters cleaned. New lifters. Block reassembled with assembling oils. New waterpump, camblet, tensioners, idler, headgasket, intake gasket, exhaust gasket, rocker cover gaskets, throttle body cleaned out, intake manifold sat in cleaning solution. New frost plugs in block. Block and rocker cover painted.
4G61T
4G67 1.8L head
Hy-Lift Johnson noiseless lifters
VR-4 cams
TD05H ?Big? 16G Evo 3 Turbo, 070 exhaust housing
Evo 3 Exhaust Manifold
Modified E39A Intercooler - 2.5" inlet/outlet
Evo/VR-4 Intercooler piping
Evo ?609? AFM
4G63 N/A Inlet Manifold
60mm throttle body
K&N / M?s Air Filter
GFB Stealth FX Blow Off Valve
510cc Injectors
Walbro 255lph Fuel Pump
Turbotech Precision Manual Boost Controller
Genuine Ralliart Oil Cap lol Razz
Single board EPROM chipped VR-4 ECU with new caps, socketed.
Chip features -
VR-4 RS Ignition & Fuel Maps
Injector Compensation &
Injector Deadtime Adjustment for 510cc Injectors
AFM Compensation for Evo AFM
Fuel Cut Removal
Octane Reset on Start-up
?Stutterbox? Launch Control set at 5500rpm
E39A VR-4 Flywheel resurfaced
Brand New Evo 3 Organic Clutch Plate
Brand New Evo 3 Heavy Duty Pressure Plate (20% more clamping pressure vs stock Evo 3)
W5M33 Turbo Gearbox
3.545 Ratio Rear Diff
And this is where its at right now..
Currently waiting on a rear diff mount bush, other than that its basically drivable! Need to sort out some proper intercooler piping and solid mount the cooler..
And heres a vid of startup
http://youtube.com/watch?v=fwksxr-2brY
PostPosted: Thu Jan 31, 2008 1:26 am
Yeah, it's official. I still hate you. :P
Looks awesome man. Get her running and post up some vids!
PostPosted: Thu Jan 31, 2008 11:12 am
fruit and banana prick :axe:
i hate you guys across the pond, you get all the cool shit
95 tsi awd- 13.78
PostPosted: Thu Jan 31, 2008 11:14 am
hahahahaha... wOw... nice work.
PostPosted: Thu Jan 31, 2008 2:45 pm
Thanks. After owning 4 n/a Mirages over nearly 6 years, its good to finally see a turbo in my engine bay :lol:
Apparently the rear diff arm/bush should be here in about 2 weeks, so i've got until then to sort the other minor stuff I have left to do. Argh, can't wait to drive it!! :twisted:
 Post subject: sdf
PostPosted: Fri Feb 01, 2008 3:46 am
I want one!!!!! I am in love with that wing with the brake light in it!
PostPosted: Sat Feb 02, 2008 3:36 am
4g61t Delinquent
is it me or do the headlamps look more clear?
I own a CSM.
PostPosted: Sat Feb 02, 2008 5:48 am
Damn I like that car, I don't know why they didn't make one awd from the factory here.
