It is currently Mon May 13, 2024 2:30 pm
PostPosted: Sun Sep 09, 2007 11:57 pm
Just curious I would like to see some pics and get some ideas for mine b4 I start the transformation...
PostPosted: Thu Sep 13, 2007 7:00 pm
I ran my 85 Mirage Turbo in H-stock from Jan-June. If you can find some sort of swaybar that will work (I never did) it should be a decent competitor, maybe not on the national level but locally at least. Van ran his 88 as well and he has some sort of special Koni's made that I bet were pretty sweet but still showed a lot of body roll. I beat a national level driver in his 91 Civic si on one of my very best days but was right back to #2 the next event.
Not sure about the next Gen Colts though. Grassroots Mag looks like the are going to feature a newer Colt next issue, keep an eye out for that.
Things are different now in my Miata now though :twisted:
1985 Mitsu Mirage Turbo 5-speed
PostPosted: Thu Sep 13, 2007 7:41 pm
i run my 92 Summit sedan in the local autoX, in H Stock with nothin but Kumho all-seasons and determination :p
Got a video of one of my runs from the last event. i know i'm not fast, and i never place more than between bottom or middle of the pack, but i have fun doin it, so it's all good.
PostPosted: Fri Sep 14, 2007 12:56 pm
I do :P
89 mirage #666/1200
89 colt E $2006 GRM
PostPosted: Mon Sep 17, 2007 1:30 am
I do :P
I know that matt but thanks....
PostPosted: Mon Sep 17, 2007 4:02 am
FYI You can get a front and rear sway-bar from:
http://www.whiteline.com.au/
Just look in their catalogue under "Mitsubishi->Colt RA,RB,RC,RD"
I have rear sway bars on both my Excel's and they share the same rear trailing arm suspension. However mine are made by this company:
http://www.k-mac.com.au/
PostPosted: Mon Sep 17, 2007 12:24 pm
I do :P
Will talk :rolleyes: There are a couple tricks I've learned.
89 mirage #666/1200
89 colt E $2006 GRM
PostPosted: Tue Sep 18, 2007 2:23 am
awesome... I just need to figure out why I keep on eating turbo's first..
PostPosted: Sat Sep 29, 2007 9:33 am
I have before I sold mine.... http://www.youtube.com/watch?v=pIC_kQR7qc8
http://www.youtube.com/watch?v=JjeMJItu6iw
http://www.youtube.com/watch?v=NeO19Z-0v8g
Get some energy suspension bushings and endlinks. Big bang for the buck as far as handling. Not a cure all though.... http://www.energysuspension.com/pages/swaybbct.html
Good luck!
Van
Children in the front seat can cause accidents. Accidents in the back seat can cause children.
PostPosted: Sat Jan 05, 2008 5:41 pm
i autocross my 4th gen 4g63t colt!
heres a vid!
http://videos.streetfire.net/video/b5a9 ... d24d0d.htm
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Sun Feb 17, 2008 1:31 pm
I'm hoping to start autoxing my colt this spring.. I tried auto x last year for the first time, and now i'm hooked!
PostPosted: Sun Feb 17, 2008 1:53 pm
i took 1st in dsp and second overall last year in my 06 lancer, and intend on running the 4g63t swapped 89 mirage turbo once this year.
but every other event ill be racing a mugen si with nt01's!
12 dodge charger hemi r/t max
08 r6 modded on e30
89 mirage turbo 4g63t - fast
88 dodge colt 4g32bt - project daily driver
PostPosted: Fri Mar 27, 2009 10:43 am
This Colt I now have will be seeing much AutoX time and track days. Unfortunately, due to the AWD and 4g63t swap, at Solo competitions I will be forced to run in the Prepared class X, also called Open Prepared, which basically has very few rules. I will be running Konig Britelites with Hankook Ventus C50 DOTR slicks. Here in Cincinnati there are very few XP cars, but the two that ran last year were a LS1 swapped FD and a consistent FTD WRX. I think that given the current suspension setup and weight of this Colt I will be giving that FTD WRX many difficulties. And if I am not giving him enough problems then there is always room for improvement. I dunno how you can argue with 2,500 pounds of AWD go-kart though...
PostPosted: Fri Mar 27, 2009 11:33 am
This thread is from 07
:axe:
PostPosted: Sat Mar 28, 2009 11:34 pm
Yeah, I saw Feb 19 but not the 2008. Oh well. I'll be autocrossing my AWD go-kart. That's all I wanted to say.
