It is currently Sat Jun 15, 2024 11:56 pm
 Post subject: vr4 hubs install
PostPosted: Tue Aug 28, 2007 10:06 pm
ok guys i am getting a set of galant vr4 hubs for the colt... i am going to put my dual piston calipers on it for better braking but other than the hubs and rotors what else would i need to swap it into my colt?
PostPosted: Wed Aug 29, 2007 3:13 am
You will need the hubs, rotors, calipers, and brackets for the install.
PostPosted: Wed Aug 29, 2007 9:55 pm
i can use my gsx 2 piston calipers
PostPosted: Wed Aug 29, 2007 10:28 pm
late 1G 2 piston calipers, VR4 calipers, Diamante Calipers, and 300GT-SL
calipers are the SAME calipers.......
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Wed Sep 05, 2007 7:20 pm
Seasoned Member
Then you will need to grind the shit out of the back of the "ear" where the hub mounts to the strut, wallow out the strut bolt holes a bit and get camber bolts. This was the only way I could get gvr4 hubs to work on my old gt. Maybe custom front suspension and camber plates would have fixed it with less hacking but I didn't have the money to find out.
