It is currently Tue May 21, 2024 11:05 pm
Post new topic  Reply to topic  [ 44 posts ]  Go to page 1 2 3 Next
 Post subject: AWD guys. Front Axles?
PostPosted: Tue Jan 23, 2007 2:33 pm
I"m about 80% of the way done with my car. I'm now putting the front axles in. I used the factory turbo colt passenger side. and i went to use the AWD dsm drivers side. But it seems to be tooo long.
What axles did you guys use.
PostPosted: Tue Jan 23, 2007 3:01 pm
In Jason's awd dvd, he says you can use the 4g61t(c53) axles.
PostPosted: Tue Jan 23, 2007 3:04 pm
Ya mooch.
There's an easy answer to most any swap related questions.
What kind of car are you swapping into?
Ok, then that's what you use.
Mirage turbo axles were "designed" for the turbo style transmission. I am running those axles and they work perfectly. I can't speak for 1.5L manual or auto or 1.6L NT axles.
PostPosted: Tue Jan 23, 2007 3:08 pm
Assuming you are swapping into a 3g c/s/m.
PostPosted: Tue Jan 23, 2007 3:49 pm
89 turbo hatch. I dont have the stock drivers side axle. It broke when i first got it. So i put in a 90fwd dsm axle.
And yet another set back #-o
PostPosted: Tue Jan 23, 2007 3:51 pm
You can use a GVR4 or AWD DSM intermediate shaft that bolts to the block, but you should (have to?) use a Mirage turbo axle.
This is the only picture I could find. This is the passenger side axle though. 1.6L T on the left, 1.5L manual on the right. 1.6L T is the axle that will "snap" into a turbo tranny. That 1.5L axle will not lock into the transmission
PostPosted: Tue Jan 23, 2007 4:23 pm
Well does anyone happen to have that part of the axle.
PostPosted: Tue Jan 23, 2007 4:25 pm
Try www.car-part.com
PostPosted: Tue Jan 23, 2007 4:49 pm
No go. :(
PostPosted: Tue Jan 23, 2007 4:51 pm
Why not? I saw hundreds of them. 91 Eclipse, AWD left axle.
"stub shaft"
"includes int shaft"
"mid shaft"
PostPosted: Tue Jan 23, 2007 4:53 pm
Wait.. maybe your confused..
I have a drivers side 2piece axle from a AWD talon. I put it on, and it wont fit. its a bit too long, and i cant get the hub to bolt to the strut.
PostPosted: Tue Jan 23, 2007 4:55 pm
Ok, so keep the part that bolts to the block, and find a Mirage Turbo "axle".
I got both my pass and driver axles from Carquest. $74 each, brand new, lifetime warranty
PostPosted: Tue Jan 23, 2007 5:13 pm
Well i guess thats where i'll be going. Wouldnt happen to have a part number? I've been to a few Auto parts stores and they always give me the wrong one. :cry:
PostPosted: Tue Jan 23, 2007 6:09 pm
Dside carquest p/n RDS 322 (It might be RDS 3229, I can't read the number anymore). It comes up if they search for 1989 Mirage Turbo
Pside carquest p/n RDS 3212
PostPosted: Mon Aug 27, 2007 5:48 pm
Some please archive this thread!!
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
