It is currently Sun Jun 16, 2024 5:32 am
PostPosted: Thu Jan 04, 2007 5:38 am
Does any body have a picture of what the did for the motor mounts on a hatchback AWD swap. I did a few searches, but found that not many people have actually done/doing this, just a lot of finger banging.
There was a write up online from some guy that worked at junk yard or something, but at the time I read it I was not considering a AWDswap.
I was going to bend a peice of 1.25 tubing to make a new front/rear cross member but it does not look like it will fit between the T-case and the sway bar/ rack area to get to the stock mounting point.
PTTcolt (I think that is his name on here) came up with the idea to make a plate on the firewall, but I am afrad the firewall might flex.
I also tossed the idea around about making a motor plate with tubes running from the frame rails across the car and having the motor plate meet those. Whatever I do will be done this weekend.
I know somebody is going to recamand the CD, but I don't have enough money to do this swap, let alone buying directions on how to do it. I am just looking for a idea, not directions.
Just to prove I am not a finger banger here is a picture of the ford 8.8 under the rear of my car, sorry camera phone. Please keep this picture on these forums as I don't want the world knowing about my swap (yet!).
89 Colt GT, T4 T61, 2.0L, .
PostPosted: Thu Jan 04, 2007 9:19 am
The DVD will give you plenty of ideas :)
PostPosted: Thu Jan 04, 2007 11:34 am
:o You ass hole I knew you were up to something..
Thanks for killing my dreams of having the fastest colt at the shoot out. :depress:
Let me know if you want some pictures of diff AWD swapps. I got a ton.
PostPosted: Thu Jan 04, 2007 1:58 pm
It is cool to see that you are going to run a solid rear axle setup. Are they available with 3.545:1 gearing?
PostPosted: Thu Jan 04, 2007 2:06 pm
Yeah, I have bee working on it for a about 2 months now.
Car is stripped. Roll cage and all suspension supports are in.
BTW> I hope other who are doing or are considering a AWD swap know that you need to renforce the chassis.
Engine and trans are sitting in the car (nothing new, just a bunch of junk).
Funds I have at the moment
100$ summit gift card
Mabye 300$ from a side job I hope to do saturday
Things I need:
Full clutch set-up (bearing/plate/friction/flywheel)
Fuel cells (need two)
Fuel lines and assorted hardware.
Things I want
rebuilt trans
rebuilt motor
Things I really want
DOG BOX!!!
Twin disc clutch!!!
So as you can see I don't at this point even have the money to finish the car, so don't get to exited about it getting done. I am just doing what I can with what I have.
Hence the reason I don't want the hype behind it just incase it is not done by summer.
PostPosted: Thu Jan 04, 2007 2:10 pm
LOL as for the gears...Man that was funny.
Mitsu advertises there gears as 3.545 or whatever. Ford advertises there gears as 3.55. I thought that is close enough. Mixed 4.10 and 4.11 gears in trucks is very common.
So I get the ford rear end (thanks PTTcolt) and we pop it open. 39/11 tooth count, gear ratio 3.545......
The mitsu rear end has the same tooth count.
PostPosted: Thu Jan 04, 2007 2:11 pm
Running some spray? :twisted:
PostPosted: Thu Jan 04, 2007 2:12 pm
Awesome 8) What are these rear ends out of?
PostPosted: Thu Jan 04, 2007 2:23 pm
Thunderbird turbo coupe. Even comes with a limited slip. The rear end is about 5/8 of a inch wider. It is not a big deal and looks good, but I was told I can put ranger or mustang axles into that rear and to get it a little narrower.
If I come into some cash I might consider doing that, but at the moment it will stay the way it is.
The bolt pattern will have to be redrilled from 4X108mm to 4X114.7MM. And I plan on making a hub adapter on the lathe over at PTTcolts shop.
Other things:
I was just reading the LILevo sitwe and I take it you ran a 2X2 channel from frame rail to frame rail and used that as a mount? Intersting..
I also stumbled across a post about AWD talon struts in the rear needing a aluminum spacer for the bottom bolt. If you take a propane tourch and head up the spacer in your colt rear strut it will melt the rubber and slide right out. This spacer slides right into the AWD spacer. I did tack weld mine in there to make sure it would not move around. Just a FYI.
PostPosted: Thu Jan 04, 2007 3:10 pm
I never had a mount from frame rail to frame rail. I had a short piece of 2" box steel above each front subframe mounting point welded to the frame. Never had any issues with such a "small" mount. I reduced it further on this second AWD swap. I don't forsee any problems. The welds would be the weakest point and they are pretty strong as it is.
If something does happen to go wrong it's a simple mount to re-do or reinforce
PostPosted: Thu Jan 04, 2007 5:09 pm
Can you post a picture of what you talking about? i cant picture it in my mind at all.
PostPosted: Fri Jan 05, 2007 4:21 am
The hatch does not have a subframe aside from the small cross member that runs under the oil pan, but will not work with AWD as the T-case needs to be there.
After a lot of thought, I am going to remove the rack and bend a plate of 1/8 to fit the fire wall just behind it where it goes from one sheet thick to 3 sheets thick to support the steering.
I am then going to run a bracket off that plate and connect it to another bracket from the block. Where these two meet I will use two bolts threw the two brackets instead of one as I don't want it to try to pivot.
As for the front mount, becuase of the size of my turbo I am very limited on room. My plan it to basicly make a new one piece L shaped mount that runs down the front of the block and then to the front core support where the factory cross member bolts to.
I will start on this tomarow and try to have it finished by sunday night.
I just landed a t-belt side job on a 96 lexus SC400 so that will put a few hundred dollars more to the colt, but will take a few hours of my time away.
As for the dual tanks I am not going to run N2O I am planning on a race gas/ pump gas dual fuel system.
I live 40+ miles away from were we race and it costs me almost 60 dollars a weekend just getting there and back on race gas. So I needed something a little easier on the wallet.
PostPosted: Fri Jan 05, 2007 4:48 am
LILevo, I like what you did with that rear mount. Nice job.
As for the front I am not knocking you design in anyway, but why did you decide not to just extend the mount a few more inches forward and catch the factory mounting holes?
As for the tarns mount I just moticed when I set it in that it was hitting the trans...LOL Lookignat your pictures is like looking at my car...kinda funny.
I have not gottne mine settled in yet, but it looks like the 5th gear cover on the trans might hit the frame rail. Not sure yet as I have not got everything straightened out yet.
LOL I just went back and was looking at the pictures again..looks like you know about the 5th gear cover as it is not on the tranny if I am seeing that correctly. Nither is any of the shift ball/spring bolts either...You using a dummy tranny...NICE...you da man!!!!
Also looking a little closer..Looks like you took the rear mount bracket and turned it upside down...good mod. Starter clear OK?
I gotta say I am pretty impressed. If I had 50 dollars I would buy that CD.
PostPosted: Fri Jan 05, 2007 12:05 pm
Yes If you turn the Rear mount up side down it does clear the starter. and the tcase..
As for the front. I took the same approach as lilevo did. Going from side to side. I thought about doing it like you mentioned. But i also thought that It might flex tooo much. I dont like flex. maybe i'll redesign the front today when i go into work today. i'll take pictures if i make it that way.
PostPosted: Fri Jan 05, 2007 4:03 pm
Heres what I wanna know, how much is a 4 door Mirage with AWD gonna weigh? I would have to think close to 3000 lbs?? When that is all said and done, seems like you have an Ok swap with a stinky fuel cell, wobbly front mount, banged in frame rail and a car that would probably loose to a FWD one from a roll pretty bad?
