It is currently Tue Jun 04, 2024 8:16 am
Post new topic  Reply to topic  [ 74 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Dec 01, 2006 5:11 pm
Yet get the trany and transfer case. get everything you can from that guy.
charles
PostPosted: Fri Dec 01, 2006 5:59 pm
Charles, you spend too much time on the road. Leave out his tranny, and go with a new stage 3 from TRE :evil:
PostPosted: Fri Dec 01, 2006 9:53 pm
I got a 4 bolt for sale with axles if you are looking for one just in case that deal falls through.
1999 Ford Contour SVT
PostPosted: Fri Dec 01, 2006 10:46 pm
New stage 3 sounds good I will take the old one. Change you name from silky to Bigtime
PostPosted: Sat Dec 02, 2006 6:11 pm
Where are you Spinmaster? I thought I sent you a PM. Give me a contact or call (757) 651-2524,cell, anytime. Very interested in your deal.
Today I opened up the front. Was in worse shape than I thought. Sort of pushed back and left. All jammed in! Power cutting wheel, nibbler, and shears got it opened. Condensor is out; will pull radiator tomorrow (an easy work,now), and take off the doors and fenders.
Once motor is out, I should be able to see things.
QUESTION: Will I have to get a different starter to match the smaller AWD flywheel? Or is there any problem there?
PostPosted: Sat Dec 02, 2006 7:39 pm
Yes Bill you will need to get a awd Flywheel and Cluch I will take your old ones as well. :lol:
PostPosted: Sat Dec 02, 2006 8:15 pm
IIRC, the 4g61t starter will work with the awd flywheel.
PostPosted: Sat Dec 02, 2006 8:39 pm
OK. Thanks for the starter info.
I now know that I need an AWD tranny(from TRE), an AWD flywheel(from DSMTrader), and a 4-bolt rear end, axles, and cups(from Spinmaster?). I'll use my old starter, clutch, and pressure plate. Where are you Spinmaster? Or I could go ahead and get the 4-bolt on line. Need to get'r dun.
I also need to line up the square steel tubes for frame support, and the motor mount support fab. I don't have that info. in one place. I need to review and get some number and stock sizes, unless SOMEONE :wink: happens to have the info. handy.
PostPosted: Sat Dec 02, 2006 8:49 pm
Hey Silky do you want my carbon fiber hood. I'm going to get a galant VR4
PostPosted: Sat Dec 02, 2006 9:05 pm
:-? Err, No. I am going to use a regular hood (from the "frontclip"). I want to put my old scoop back on as well as get some vents.. Easy with metal; hard with fiber. Anyway, my carbon hood is not lost. The damage was underneath and can be covered with fiberglass. The top finish is fine.
PostPosted: Sun Dec 03, 2006 6:27 pm
Ok, I have gotten the car front and both outside fenders removed. The radiator is trash unless I can get a new core for the alum. end tanks. The two fans are gone (they also melted some on the manni.). I have to test the IC and if good will do some fin reshaping. Same for the condensor. Couldn't get it into the bay today, but engine pulling due tomorrow. Alternator is trash. (I think I have another.) Water pump is probably good. DNK about the pwr steering pump.(I may have another one of these, also.) It's nice to have a disassembled Colt available. Next stop: wait for engine pull and parts acquisition.
PostPosted: Sun Dec 03, 2006 6:42 pm
Sounds like your getting some work done. Hope you liked the pictures. hope they help you. as they did me.
Let me know if you need help. I'll do what i can.
PostPosted: Mon Dec 04, 2006 9:31 pm
:( Well, I am now in the wait-around category. Located my other alternator and power steering pump, so tha part is OK. Got the condenser, radiator, and outer fenders off. Car was to go in Sun. eve, but didn't. Supposed to go in this eve. I hope so. Waiting now.
PostPosted: Tue Dec 05, 2006 4:29 am
I would appreciate any links to instruction. :) :-?
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Tue Dec 05, 2006 4:53 am
Geoff, we would so be doing this if I got the one :wink:
