It is currently Sat Apr 27, 2024 4:33 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
 Post subject: Magnus intake mani.
PostPosted: Mon Jun 05, 2006 10:58 pm
I had a magnus SMIM from my talon, figured what the hell. I'l put it on the colt. Got the stock 1.6 intake mani off rather easy. And man, them ports are SMALL. So i got the new gasket and put magnus on. Bolted it up. Everything was looking Good..
.... Untill it was time to put the throttle body on. The brake booster is in the way. So i worked with it, and got it on. to find out the TB elbow touches the brake like, so i pushed it outta the way enough to clear. Get it all back together and it looks nice.. Go for the test drive.. As soon as i would give it gas, the engnie would rock back just a bit to pinch the cable agenst the wiring harness. So it would hold WOT till i'd push the clutch in and let it break loose..
All in all. Its nice. but takes some work to get everything in order.
PostPosted: Mon Jun 05, 2006 11:54 pm
1595 cc's of fury
Good to know, since I'm planning on running one myself.
PostPosted: Tue Jun 06, 2006 12:09 am
I'll take some pictures tomorrow to show the closeness. Deffently noticeable differnce
PostPosted: Wed Jun 07, 2006 2:32 am
Did you put the smim on an otherwise stock 4g61t?
PostPosted: Wed Jun 07, 2006 9:03 am
Nope.. It has some other things done as well now.
PostPosted: Wed Jun 07, 2006 9:38 pm
Did you open up the ports on the head?
'89 Plymouth 200GT 4g61t , evo316g, fmic, 1g cams, cyclone intake, 1g throttle body, 2.5 hard pipes, 190 walboro, 650's, 2g o2, 2g ex mani,3" mandrel, ACT 2100, Fidenza flywheel, Unorthodox underdrive pulley, SBR lsd, , AEM wideband, tuned by maf-t, 2" drop, gr-2's, brembo
cross-drilled, metal masters, 205-50 Falken Azenis, etc., 280 whp @ 256 tq
PostPosted: Wed Jun 07, 2006 10:10 pm
What do you mean? The ports are the same size as the 2.0 Unless i got the 2.0 head on my car.. Hmm
PostPosted: Sun Jun 18, 2006 7:37 pm
1595 cc's of fury
1.6 ports are much smaller and oval in shape. You may have a 2.0 or 1.8L head...just look for the casting near the t-stat housing stamped 2.0, 1.8, or 1.6.
PostPosted: Sun Jun 18, 2006 9:56 pm
:pics: j/k
PostPosted: Mon Jun 19, 2006 3:41 am
Is the butt dyno able to tell a difference in performance? what set up are you running?
PostPosted: Mon Jun 19, 2006 9:41 am
Forgot about this thread.. It sold on ebay last tuesday for 410 shipped.
On my head, it say 1.8. that good or bad? lol
PostPosted: Mon Jun 19, 2006 12:14 pm
For the 4g61, 1.8 head is good. It has the in/ex port sizes of the 2.0 head and the combustion chamber size of the 1.6 head. The 2.0 head has a larger combustion chamber, therefore lowering you compression ratio a bit. The 1.8 head allows more flow with the same compression ratio on a 4g61t. :wink:
PostPosted: Mon Jun 19, 2006 1:10 pm
Sweet.. I was putting my exhasut back on the other day (welded a bung for my WBo2. and found out my car has an alum. flywheel. haha
 Post subject: Re: Magnus intake mani.
PostPosted: Fri Dec 08, 2006 5:23 pm
OMG! that "MAY" explain my accident. When I was doing autocross, I florored the gas right at the closing run, and the throttle body stuck open. (yes, I had a bad crash, covered elsewhere.) Afterward the TB plate snupped shut alright and the cable was not pulled tight. So, the physical evidence did not support my view...UNTIL NOW. Well, you can't re-do. But I feel a little better now. Thanks
PostPosted: Fri Dec 08, 2006 6:04 pm
Means you need run poly mounts at least a rear one when running a Magnus SMIM...
LC '01 Accent GSI - Silver
