Updated to reflect the fact that the archives no longer house the photos that made this thread complete.
The following resources are available:
Factory Mitsubishi PDF's - The most popular PDF's for CSM/DSM/GVR4, transmission, carbs, etcs
http://www.lilevo.com/mirage/
Online ASA parts lookup program. Must have translator unless you speak Russian. Very simple layout and for each picture, you see a complete list of the associated parts, for those pieces pictured.
http://mitsubishi-motors.kiev.ua/1/#
Parts look-up database. Also, you can input an OEM part number and it will take you to the model and period it was produced for.
The program covers ASA Japan, USDM, EDM, and GEN EXPORT
This webpage is absolutely amazing!!!
http://www.partsbase.org/
ASA programs for those times when you don't have the internet handy.
EUROPEAN ASA
http://www.kaxlon.com/dsmecu/2013/MMC_ASA_EURO.ZIP
GENERAL EXPORT ASA
http://www.kaxlon.com/dsmecu/2013/MMC_ASA_GEN.ZIP
JAPAN ASA
http://www.kaxlon.com/dsmecu/2013/MMC_ASA_JAP.ZIP
US ASA (Mitsubishi Afersales Support Application)
http://www.kaxlon.com/dsmecu/2013/MMC_ASA_USA.ZIP
USDM Mitsubishi Chassis codes - holds true for other regions but some codes cross over and lack turbocharging, certain 4wS etc.
http://img.galantvr4.org/143000/143059-0-0-0.jpg
Mitsubishi DSM parts catalogue: Just about every part with MD numbering, you can shake a stick at!
Tranmission parts, engine parts, shifter cables, nuts, bolts, whatever, it has it.
http://www.gmb.be/CJD_parts/CD2/Catalog ... ar/89d.pdf
Russian website with tons of Factory Service Manuals (Mitsubishi) but in point and click .PDF
http://www.mitsubishi-motors.kiev.ua/info.php?id=20
For members of
http://www.galantvr4.org:
ASA installation instructions -
http://www.galantvr4.org/ubbthreads/sho ... =0&fpart=1
Online CAPS/ASA for any Mitsubishi:
Off-Road Mitsubishi PDF's:
Montero, Pajero, Conquest, Starion, 3000GT, Stealth, Eclipse, Laser, CAPS and more
http://www.mitsubishilinks.com/
Russian link that some of the info here, came from
http://indy.pp.ru/GDI/Docs/
CAPS
WIN CAPS US V3.41
http://www.mitsubishilinks.com/fsm/wincaps-setup.exe
US ASA
http://www.mitsubishilinks.com/fsm/mmc-asa_usa.exe
Instructions for ASA:
Welcome to the new Mitsubishi Aftersales Support Application It's an updated version of CAPS, but more powerful in it's searching capabilities. For example you can see what cars share parts in a single click! No more guess work!
**If you're running VISTA, there's a fix at the bottom for you**
Here is the download link ASA link
The files you want to download are the ones under:
"Mitsubishi ASA Japan (MMC ASA)
MMC ASA catalog of parts for all models of Mitsubishi Japanese market.
Updates via the Internet."
The password for the archives is "dsm-club.org" (without quotations)
Installation:
Once you've downloaded and extracted the two ISO files. Just mount them (with Daemon tools) or burn them with Nero or something similar.
Run disc A and choose "Setup". The program will start to install and you will get this first screen:
Choose "English UK", click OK
Next screen:
Check the "HASP HL" box, make sure nothing else is checked.
Click FINISH
Next screen (after the HASP HL drivers are installed):
Choose "Custom Install"
Next screen:
Choose your hard drive to install to, then check "Single User (Full) - Recommended"
Click NEXT
The program will install.
:::::::::::::::::::::::::::::::::::: NINJA EDIT ::::::::::::::::::::::::::::::::::::
Once you reach the final screen, DO NOT click the "finish" button.
If you do, the program will auto-start upon completion and give you an error message.
You must perform the tasks below before finishing the installation.
Then and only then, will the program work with the crack folder ".dll" file in the [PROG] folder, and the REGISTRY file installed [double click on it] See note on next line for Vista 64 users.
Make the changes below to the REGISTRY file before installing it.
You need to crack it.
Browse your ASA Jap Disc A and find the "Crack" folder. Copy the file mmData.dll to this folder:
x:\MMC\ASA\M00\PROG\ (where "x" is the drive you installed to)
Then double click and run the MMC.REG file to update your registry.
The program will now work.
It works practically the same as CAPS and it works with Vista after you apply the fix below.
With x64 Vista you will need to change the registry key that is being entered. Just open it up in notepad (right click, open with, choose notepad)
When inside, one line will say [HKEY_LOCAL_MACHINE\Software\Licenses\], just change that to [HKEY_LOCAL_MACHINE\Software\Wow6432Node\Licenses\] and save it, should work after that.
the program is a 32 bit application, therefore runs in vista 64's 32 bit shell, which is kept separate to all the 64 bit stuff. just like you have a Program Files and a Program Files (x86) folder in x64.
For Vista x32 there would be a similar fix, but I haven't worked it out yet.
** I did not write these instructions, they were posted on
http://www.4gtuner.com by Liberoz **
Short version of the instructions as written by Legume of the same forum...
1) extract file from rar. password: dsm-club.org do both flies A and B
2) mount disc A to magikdisc and run
3) select english
4) select HASP HL
5) select custom install
6) select single user (full) --> next
7) program will install but dont run until crack is installed
when disc 2 is asked for I unmount disc 1, mount disc 2 then click continue.
Browse mounted disc A and find the "Crack" folder.
Copy the file "mmData.dll" and drop it into the "PROG" folder
of NEWLY INSTALLED ASA
browse mounted A disc and open CRACK folder
*Hear ye, Hear ye! Coming to a Sticky near you, this just in*
BEST MANUALS TO USE (FOR TURBO CHARGED MODELS)
Representative pictures of the dealer manuals located here ...
Click me for better view of the manuals.
As stated before the manuals are representative, but the only difference I have seen when referring to the
1989 C52 model, is the addition of the wording, "
Colt/Summit Colt Series 2000"
The 1989 Colt/Summit Turbo manual cover shows a black background with white writing.
C10 Body Styled cars 2nd Generation
Dealer Manuals generally a two volume set -> Names can include Colt, Summit, Plymouth, Mirage, Colt Wagon, Conquest.
Covers North American sales years from, 1985 to 1992 (Canada received sales until 1992 of the C10 body style).
-> Volume 1 Engine, Chassis & Body
-> Volume 2 Electrical
-> Volume 3 ECI - Turbo Driveability Troubleshooting
Everything you need to know about ground point locations, fluid specs, internal tolerances, body panels, diagnosing every sensor and component on the vehicle. Turbo reference material supplement to the regular dealer manual; info concerning parts, operation, inspection, diagnosing problems and re&re installation of turbo system.
C50 Body Styled cars 3rd Generation
Dealer Manuals generally a two volume set -> Names can include Colt/Summit Colt Series 2000, others (?).
Covers North American sales year 1989 - 1500 Models produced total.
Everything you need to know about ground point locations, fluid specs, internal tolerances, body panels, diagnosing every sensor and component on the vehicle. Turbo reference material supplement to the regular dealer manual; info concerning parts, operation, inspection, diagnosing problems and re&re installion of turbo system.
Sources:
EBay.com, Ebay.ca and the classifieds in your local swap papers.
Manual sets can be had from $1 to $25 at the most at the time of this post.
Generally not available from the dealer any more Chrysler or Mitsubishi, however if you get the right person at the parts counter you can ask for this courtesy of HondaHunter;
Mitsubishi still carries them. I was quoted at
$139.65 USD and I believe its for the whole set.
I believe its for the turbo....I told the parts counter guy
C53A
P/N: MSSP006B89
NOTE: the parts counter guy's handwritting was *shystier* (little edit for wording
) than mine so the S's might be 5's and the 0"s might be o's."
Dealer or Ebay.c* may also still carry the original
Volume 3 of the C10 body style car manuals (
ECI - Turbo Driveability Troubleshooting); dealer manual (may be Chrysler #)
# 81-699-7032
BEST MANUALS TO USE (FOR NON-TURBO MODELS)
Dealer Manuals generally a two volume set -> Names can include Colt, Summit, Plymouth, Mirage, Colt Wagon, etc.
Dealer Manuals generally a two volume set -> Names can include Colt, Summit, Plymouth, Mirage, Colt 200.
Covers North American sales years, 1989 through 1992.
CC Body Styled cars 4th Generation - while not widely discussed on this site, they are pertinent non-the less!
Dealer Manuals generally a two volume set -> Names can include Colt, Summit, Plymouth, Mirage.
Covers North American sales years, 1993 through 1995(?).
Sources:
Generally not available from the dealer any more; Chrysler or Mitsubishi.
GOOD MANUALS TO USE (FOR NON-TURBO MODELS)
CHILTON Colt/Vista 1990-93 3rd + 4th Generation C/S/M plus Vista models
Representative picture of the Chilton manual located here ...
One volume book, Chilton id #20342, ISBN 0-8019-8418-1
While not the definitive dealer manual set, this book includes much of the same material in copied form and the binding is almost as thick as the two dealer manual sets together. Wiring diagrams and vacuum diagrams are included and cover more than just the C50/CC body vehicles; also covered are the Vista wagons and their respective power train assemblies.
U.S. and Canadian models are both shown in comparison.
Sources:
Available online everywhere, including Amazon.c*, Ebay.c*, large book retailers such as Indigo/Chapters.
Priced around $15 to $30 at the time of this post.
CHILTON Import Repair Manual 1988-92 3rd Generation C/S/M
I have yet to review the contents of this book, and as such can only report on the contents as advertised by Chapters.ca and the Publisher respectively .... quote
"Offering extensive coverage of virtually every car imported into the U.S. and Canada, this is the most up-to-date service manual made for import car owners. Features thousands of detailed illustrations, charts, and line drawings."
Chapters.ca
"Chilton's Perennial Edition Service Manuals contain repair and maintenance information for all major systems that may not be available elsewhere. They include repair and overhaul procedures, thousands of illustrations, and troubleshooting. This 1992 Import manual offers a wide range of repair information on imported cars from 1988 to 1992."
The Publisher
Sources:
Available online everywhere, including Amazon.c*, Ebay.c*, large book retailters such as Indigo/Chapters.
Priced from $40 to $60 at the time of this post.
MANUALS THAT WILL COVER THE BASICS!
Representative pictures of the manual located here ...
Click here for a better picture of the manual.
Mirage, Galant, Precis, Tredia, Cordia Service Manual
To quote leeds who selflessly donated his time to get me these pictures:
Our cars are pretty much covered when it comes to almost everything, including even fixing small dents on body panels, both carb and injection engines are fully covered (as far as i know, the 1.3 and 1.5 c50 models that arrived to europe were carbs 1988-1990, the final 2 years of production; those engines became mpi, and dubbed GLi and GLXi. the gti was always an injection engine but after 1990 the 1.6 was dropped and replaced by the 1.8l-4g67). unfortunately the turbo charger unit itself is not thoroughly covered, with only one exploded illustration and covered in less than a page. unlike in the usa; the gti that came to europe was never turbocharged from the factory, infact, untill that crappy new colt 'cz3'; the last turbocharged colt that came to europe was the c10.
Haynes Repair Manual Non-Turbo Charged models!
1st Generation type models, NO relation to the 1.5L EFI and larger displacement power plants that fit in the C10, C52, CC body types.
Sources:
Available online everywhere, including Amazon.c*, Ebay.c*, large book retailers such as Indigo/Chapters, most likely anywhere automotive literature is carried by a parts supply business (Canadian Tire, Pep Boys, etc.)
Priced around $20 at the time of the post.
SWAP RELEVANT LITERATURE N/A OR TURBO
Books or electronic media that can make diagnostic life much easier for those with the larger displacement engine swaps that now can't use the base 1.5L reference material. Displacements include 1.6L through to 2.4L and other variations due to swapped reciprocating internals. Information located here is a great tool for comparing the electrical system of the base vehicle to that of the swapped components and how they interact.
Dealer Manuals
1990 Talon/Laser Technical Information Manual - includes turbo supplements
1990(+) Powertrain Diagnostic Procedures 1.8L (Diamond Star)
->Talon/Eclipse/Laser Electronic Fuel Injection
1990(+) Powertrain Diagnostic Procedures 2.0L (Diamond Star)
1991(+) Talon, Laser, Eclipse 4G37 equipped manuals
1991(+) Talon, Laser, Eclipse 4G63, 4G64, 4G67 equipped manuals
1989-1993 Galant (GVR-4), Eagle 2000(GTX) DOHC/SOHC
1991 Hyundai Sonata G4CS (4G64) SOHC bottom end, 1995 DOHC head with 4G64 Gears.
This sticky is by no means infallable, there may be mistakes and if there are any or you have any info to add, feel free to PM me with your concerns and/or updates. This is a work in progress that I felt was needed just so that everyone had a good sense of what was out there regardless of their knowledge base concerning the C/S/M stock models and swap phenomenon.
P.S. Anyone with info pertaining to ideal 1st/2nd Gen. manuals that aren't dealer specific and maybe have a link to a pic of one .... let me know, I'll include stuff for the 1st/2nd Generation guys too. I'm not as well versed as some of the others here on the older models. Thanks
