It is currently Sat May 11, 2024 8:30 pm
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Jan 27, 2006 11:42 pm
Vendor
Question- Is the car capable of that speed with the DSM tranny gearing? The fastest I have ever heard of a DSM going is mid 170's and with the Colt having smaller tire diameter I would double check to see if the car is even capable of those speeds. With a TRE 5th gear, 8000rpm rev limit and a maximum 24 inch diameter tire possibly? Just curious if you did the math yet and if so what did you come up with for a theoretical maximum top end?
For a top end style run I would think the most important things would be gearing and drag coefficient. Also, for your safety, I'd be sure the tires are rated up to spec. It would suck to have a blow out at 150+
PostPosted: Sat Jan 28, 2006 12:00 am
I was thinking the same thing, a lot of cars are struggling at 160-170, good luck either way make sure cameras rolling.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
"Just like in the old days-More Horse Power means more crap to pick up-lol"
PostPosted: Sat Jan 28, 2006 12:13 am
Alot of cars yes but my RX-7 Fells awsome at that speed but thats where drag and enginering coem into play.
This year I want my daily driver Colt(16g) to go 11's and hopfully the AWD drag Summit will get a chance get a run down the 1320 with what Im planing it should go 10's with even a 16g.
Good luck everyone and be SAFE.
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Sat Jan 28, 2006 1:21 am
I saw a GPS verified 184mph racing a 1000rr. This was getting near 8k.
I have 235/45/17's BFG's on the front, which gives me a near 27inch tire diameter. That with the long FWD trubo trans gearing should get me to 200+ before 8500rpm. As far as stability, it feels better at 150+ than 70-120, and Im not joking.
Braking.. Wells I hope for a big shut down area. :)
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Sat Jan 28, 2006 8:55 pm
Definitely keep us informed, maybe in another post in the future.
Last night I was discussing with a friend major tuning companys that produce super cars (Ligenfelter, Hennesy, etc.) and your race came up. I don't doubt that you can beat a TT Vette, but after I told him all about your car(500+ hp, locked/welded diff, 2000lbs), he really wanted to know what the vette was packing in that same area.
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Sun Jan 29, 2006 11:53 pm
Questionable...
POST EDITTED BY FLYING EAGLE DUE BE MALICIOUS IN NATURE OR AT THE LEAST FIGHT PROVOKING,
even if it wasn't intended to go that far. :evil:
PostPosted: Mon Jan 30, 2006 12:02 am
Negative Nancy
Why?? :P
PostPosted: Mon Jan 30, 2006 12:03 am
Negative Nancy
I know this thread is gonna get locked now!! :wink:
PostPosted: Mon Jan 30, 2006 12:09 am
Voted off the island
hahahaha
I told him to say that, just because i knew it would explode. hahahahaha
his motor could probly outpower lumpy but thats another story
jeff
'91 colt 200e 4g63 naturally aspirated
PostPosted: Mon Jan 30, 2006 12:24 am
Good read:
http://www.bobnorwood.com/300%20mph%C2% ... 0Power.htm
PostPosted: Tue Feb 07, 2006 1:19 pm
Banned for being a dick
yea lets go 150+ [-X
PostPosted: Tue Feb 07, 2006 1:28 pm
Why?
My weekend raced usually dont end until much after 150...
Current
08 535ix 420awhp
PostPosted: Tue Feb 07, 2006 1:32 pm
Aviation people distinguish air resistance as parasitic and induced drag, but the critical thing to understand is that drag increases as the square of speed. That is, while power increases in a linear fashion, drag increases exponentially with speed, in a parabolic function. For example (neglecting the effect of rolling resistance), if 100 horsepower would push a certain vehicle 100 miles per hour through the air, doubling the speed to 200 would require two-squared or 400 horsepower to overcome air resistance, while 300 miles per hour would require 900 horsepower.
-Bob Norwood.
Seeing as the car did 100mph with some 95 fwhp............
I suppose the 498whp I had was more than enough to mow through 7000rpm in 5th on the long turbo trans gears.
Current
08 535ix 420awhp
PostPosted: Tue Mar 07, 2006 11:52 am
I hope to just get mine running too...only IC pipes and shifter cables to go. I also am lookin to be out in OC that weekend. But im aiming at 14's just so i dont get disapointed, if i go faster so be it.
95 Jeep Wrangler - 4cyl 5spd, 31's...Needs more lights and a lift
91 Dodge Colt w/4G63T(Swap in progress) ...Evo III 16g, SBR Manifold, 3" GM MAS, Blue top injectors, Fidanza Flywheel, ACT 2100 Clutch, Golden Eagle Vacuum manifold Apexi Turbo timer...
www.myspace.com/coltgst
PostPosted: Tue Mar 07, 2006 12:19 pm
Just as an update....
I have commited to run in the Hod Rod standing mile shootout. It is in NC and is being held April 1st and 2nd. As long as I finish the car, I should do very well. I wont make any predicitons as to what my exit speed will be, but I will tell you, if everything comes together, it wont make much sense. :)
Current
08 535ix 420awhp
