It is currently Tue Apr 23, 2024 7:12 am
PostPosted: Sun Nov 06, 2005 1:31 am
I'd say still go for the Whitelines if you can afford them.
PostPosted: Mon Dec 26, 2005 10:25 am
Banned for being a dick
hey snow btw your car looks really good im impressed
about whiteline springs i believe i may have some on my car (they were on it when i got it) but they are really soft in the rear
PostPosted: Mon Jan 09, 2006 9:01 pm
Probably not, the whiteline springs are firm in back.
What color are the springs?
91 Colt GL "dandelion demon"
92 Talon TSi AWD - winter beater
PostPosted: Thu Feb 09, 2006 6:40 pm
im not sure ill check 2morrow when i see my car again
PostPosted: Sat Aug 05, 2006 3:49 pm
These are some good springs, much firmer than stock. Unfortunately, much softer than my buddies Eibach Sportlines. But a good overall upgrade.
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Fri Oct 13, 2006 2:46 pm
Are these springs worth putting on to help hook up in a straight line, or should I look into a different setup?
PostPosted: Fri Oct 13, 2006 6:49 pm
For straight line, back = super stiff. You will need to stiffen the back more than is usually good for side to side fun, when all you want is straight line, front end planting.
What springs are on your car right now 89coltgt?
PostPosted: Sat Oct 14, 2006 5:09 am
18 year old stock stuff afaik :wink:
PostPosted: Mon Oct 16, 2006 11:35 am
89ColtGT, I'd say these are good choice for a street/strip car. Watch my video I posted, and see how little the rear squats with the whitelines/3 yr old GR2s.
I was running all stock 1.5 springs w/GR2's, and ran a best of 12.6.
Went back to the track for a few passes with only things changed being the poly bushings and whitelines and nabbed a 12.3, 12.2, and a 12.1.
What are your 1/4 time goals? Do you 'drive' your car, or just have fun with it? What is your budget allowing ? 8)
PostPosted: Mon Oct 16, 2006 1:19 pm
Right now I am piecing together parts for the colt buildup. Plans are to drop the 2.4 in it and run an fp3065, but I may just go with a 4g63 with a 50 trim. I won't be driving daily, mostly weekends, and I don't really have to cheap out in this area of the build. I just want the thing to hook up-and keep it fwd. 1/4 mile goals? I dunno whatever I can muster with it.
PostPosted: Tue Oct 31, 2006 2:10 pm
Has anyone compared the b&g's to whitelines? I am stuck between the two. For shocks, I am thinking Koni yellows.
PostPosted: Fri Aug 03, 2007 11:36 am
hey pma I have a 15 inch rim for my colt you said that you have 195 50 tires on your Can I go 205 ? or it will hit the fender ?
Thanks for the info.
by the way I could not see your pics.
IBM
PostPosted: Fri Aug 03, 2007 1:01 pm
4g61t Delinquent
B&G's are f*cking amazing in my opinion.
I own a CSM.
PostPosted: Mon Jan 26, 2009 12:33 am
What is a good site to get a new set of springs for a 1.6t?
I have been looking for the whitelines but I couldn't seem to find a good vendor.
PostPosted: Sat Mar 21, 2009 7:14 pm
Jesse @ Revolution Motorsports has a set of Whitelines, you can get a set of B&G's from andysautosport.
