It is currently Sun May 12, 2024 6:00 pm
 Post subject: My 1992 Lancer GSR
PostPosted: Sat Nov 15, 2003 10:01 pm
About
Ok about me.. ummm I'm 23, from New Zealand. Work as a Lab Tecnician for a Vetanary Diagnostic Lab.
Engine Mods
The 1992
K&N pod filter, VR4 intercooler, boost controller (Max 15psi). Did Have 510cc injectors and evo air flow meter (since been removed)
MISC Mods
1992- Ceramic button clutch, Boost and Oil press gauges
Future Stuff
1992- New engine as the current 4G93T is stuffed, a few lil mods here and there to make it a 12 sec street car (Currently has done 13.4)
www.4G93T.net | www.4G61NZ.co.nz | www.SquidInc.co.nz | <RR>
PostPosted: Thu May 26, 2005 3:53 am
About
Engine Mods
The 1992
The 1988
Nothing as yet, its yet to be touched :(
Suspension Mods
1992-Completely standard
MISC Mods
Future Stuff
1988- Also a new engine as I bought it cheap with a stuffed one, eventually going to get a 4G63BT in :D
UPDATE!!! (Damn that original post is OLD!)
88 GSR: SOLD! :cry:
1992 GSR:
Fresh 4G93T engine, ceramic clutch, K&N pod, Evo injectors, ECU and Air flow meter. Electronic boost controller (Max 17.5psi). 2.5" exhaust, Evo small 16g TD05, 38mm Tial wastegate. Evo intercooler. Plus Various other Mods, wheels, few Evo body bits etc etc.
Pic:
Yes the panels dont match!!! I'm working on it!!
Currently has run 185kws @ wheels on a rolling road dyno and has a best time of 12.96 @ 104mph at a lower boost level than its dyno run.... Has a wee bit more in her, 12.5 is on the cards :D
PostPosted: Thu Dec 22, 2005 2:50 am
UPDATE!!
The GSR ran 12.62 @ 107mph with a slipping clutch and on the 17" wheels. Unfortunately the death rattle began two days before the summer season started and I didnt get to improve that time after spending $2000 on the car getting it ready! Oh well, see my new post about my daily driver!!! 8)
PostPosted: Thu Dec 22, 2005 5:04 am
Very nice, hope you get her back on the road soon :cry:
PostPosted: Thu Dec 22, 2005 5:20 am
I think its due back on the roads in 2007 :lol:
He's got some evil plans for it :twisted:
PostPosted: Thu Dec 22, 2005 2:43 pm
Yeah, its going to be a two year build, shooting for 450hp and mid 11 sec 1/4s.
Meanwhile..
Heres a pic of it mid-launch
PostPosted: Fri Dec 23, 2005 5:43 pm
:o WOW
PostPosted: Fri Dec 23, 2005 8:40 pm
Seasoned Member
very nice. i have a 93 4-door with an evo I/II front-end conversion for a daily beater. too bad mine is only a 1.5L though :cry:
PostPosted: Tue Jan 03, 2006 5:32 pm
Banned for being a dick
i like it
btw your sitting on the wrong side of the car :twisted:
PostPosted: Wed Jan 04, 2006 7:38 pm
no, he is sitting on the right side of the car. :wink:
PostPosted: Wed Jan 18, 2006 7:34 pm
lol what do you end up launching that thing at?
PostPosted: Thu Jan 19, 2006 2:39 am
Its around 5 or 6000rpm. Not 100% sure as i'm just pulsing the revs and keeping my eye on the tree. Really need launch control for the new setup.
PostPosted: Tue Feb 07, 2006 4:40 pm
Nice car. I want that kind of engine into my Colt :P
Heart-broken '89 Colt owner..
Sorry my bad english, I'm finnish.
PostPosted: Sat Feb 18, 2006 12:43 am
No you dont. 4G63 is a FAR better option. 4G93s are pretty weak - have a penchant for throwing con-rods through the block :shock:, even 4G61Ts shit on them for reliability.
PostPosted: Sun Jun 04, 2006 7:56 pm
Well time for an update!
Engine has been removed and pulled apart - diagnosed with a destroyed big end bearing on number 2. Car is pretty much a shell with interior at the moment. RS Gearbox being rebuilt (mm front LSD) along with a custom 4 spider centre diff :D Rear diff has had an Evo 3 plate type LSD inserted to retain the diff final drive of 3.545:1 - means I should be able to keep it in 4th rather than changing to 5th down the 1/4 if I had the Evo 3.909:1 ratio diffs.
2nd hand Autronic SMC ECU purchased, off a Proven 10 sec Lancer here in NZ. Argo rods and custom JE pistons have also been purchased aswell. Should make for a much stronger bottom end.
Few other things picked up along the way. 60mm throttlebody, Apexi power intake filter. Evo 3 orange lensed corner indicators (instead of the factory clear ones)
Full rundown on the build and history of the car can be viewed here: http://www.cardomain.com/ride/1907554
Also: have a look at my other cars here: http://www.cardomain.com/id/GSRWRC
