It is currently Thu May 09, 2024 9:22 pm
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Tue Oct 25, 2005 3:09 pm
WTF?
So, if there is a GT40 Comp wheel in a GT35r as you say, then comp wheel do you say is in a straight GT40?
I know you can get the gt40 turbo with a 50 trim 82mm dia compressor wheel or you can get it with a 54 trim 88mm dia compressor wheel. The specs are on precisions website. I am assuming since the gt40 compressor wheel is a 56trim wheel, and precision doesn't offer the gt40 turbo with a 56trim compressor wheel, only the 50trim and 54trim, then the gt40 turbo uses something larger, flows 75lbs/min, but I'm not sure of the name of the wheel, all I know is approximately how much it flows.
The 61mm wheel they list for the scm61 is a 35r comp wheel, plain and simple. AGP and a few other companies have recived heat for advertizing it as a GT40wheel, which it simply is not. You can call PTE or Garret and ask them the inducer of a GT35r's compressor wheel.
Yes the gt40 56trim compressor wheel comes in both the gt35r and the SCM61, everyone knows this and I said that from the get go. You said in your post that the SCM61 is 60-1, which is totally wrong, and if AGP receive heat then why are those specs still up there on their site?
And by the way, the GT40 comp wheel has a 65mm inducer, not even closeto an 88mm. 88mm would allow for near 1000whp, of which the GT40 can obviously not do. You can look it up, and I have one sitting in front of me.
I never said the gt40 compressor wheel had a 65mm inducer, I said that the GT40 turbos use an 88mm dia compressor wheel, in which case they do. Also, compressor wheel diameter specs and inducer/exducer specs aren't the same. The total dia. of the compressor wheel is 88mm, and I am looking at that right now on precisions website. Take a look for yourself here:GT40 turbo
1999 Ford Contour SVT
PostPosted: Tue Oct 25, 2005 4:27 pm
The mm specs you are giving are for the EXDUCER, and as far as I am concered- false advertized.
The size of a turbo comp is most often determined by its INDUCER. 61mm for the 35r, 65mm for the 40r. T-61 61mm. T66-66mm. Its not that tuff.
As it stands, the 61mm Comp wheel IS the 35r wheel, and the 65mm IS what is found in a standard 40. I will ask you to go back to the AGP61 and tel me what Comp wheel is in deed in it? Hell, ask then what cartrige they will send you if you blow it up, it sure as hell won tme a GT40 Cartige now will it?
As for the 60-1, I was think of theold 61, and the first wave of hybrid turbo's befor the Garret GT series came out. That turbo, had a 60-1 Compressor wheel. I should know, I was a Beta tester for the damn thing.
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Tue Oct 25, 2005 5:18 pm
You are right about the exducer specs. I don't really pay too much attention to the inducer/exducer specs, mainly the total lbs/min the compressor wheel flows, and the size of turbine wheel/housing.
As it stands, the 61mm Comp wheel IS the 35r wheel, and the 65mm IS what is found in a standard 40. I will ask you to go back to the AGP61 and tel me what Comp wheel is in deed in it? #*!!, ask then what cartrige they will send you if you blow it up, it sure as #*!! won tme a GT40 Cartige now will it?
Well here is your info on the AGP61:
These T3/T4 hybrids are the result of Garrett's decades of research and development into perfecting the conventional turbocharger.
Compressor Specs:
- T04S housing 4" inlet 2.5" outlet
- 56 trim GT40 compressor wheel 2.41/3.22 (61mm inducer) 65lb/min
Turbine Specs:
- T31 4 bolt outlet turbine housing available in .48, .63, .82, and 1.06 A/R ratios
- T3 5 bolt outlet turbine housing available in .48, .63, and .82 A/R ratios
- 76 trim T31 turbine wheel (stage 3)
- 76 trim T350 turbine wheel (stage 5)
Turbo Also Known As: SC61, AGP61, GT61, GTS61
Seems to me like the same 61mm compressor wheel as a gt35r, a 56trim GT40 compressor wheel with 2.40157" inducer, which is 61mm. And here is the gt35r specs while I'm at it:
Compressor Specs
-T04E compressor housing 3" inlet 2" outlet
-T04S compressor housing 4" inlet 2.5" outlet
-6 bladed 56 trim GT40 compressor wheel 2.41/3.22 61mm inducer
Turbine Specs
-GT 4 bolt outlet turbine housing available in .63, .82 and 1.06 A/R with 3" outlet
-T31 4 bolt outlet turbine housing available in .63 and .82 A/R
-84 trim GT35 turbine wheel 2.45/2.68
Also known as GT3540R, GT35R
See where I underlined GT35 turbine wheel? That's where the name came from.
PostPosted: Tue Oct 25, 2005 8:35 pm
Compressor Specs:
Turbine Specs:
Compressor Specs
Turbine Specs
I understand the turbo's name has been derived from the new hotness turbine wheels. BUT.. I will make it real simple.
In the land of turbo.
An off the shelf GT35r comes with a 61mm inducer size compressor wheel.
An off the shelf GT40r comes with a 65mm inducer wheel.
Thats it, period, fineto. There is no room to differentiate. The GT40 even has 7 main blades as opposed to the 35's 6.
It is no tthe same wheel, and calling the 61mm inducer wheel in the AGP61 a GT40 compressor wheel is blasphemy.
Current
08 535ix 420awhp
PostPosted: Tue Oct 25, 2005 8:58 pm
I understand the GT40 turbo has a 65mm inducer wheel, we both agree upon that, but the AGP61, SC61, SCM61, BR580, GT35r does have what garrett classifies as a gt40 compressor wheel in a 61mm inducer size. If you can't accept that then its not my fault, to call it blasphemy is plain ignorance because that's what its referred to by everyone in the business.
PostPosted: Tue Oct 25, 2005 9:15 pm
Its not ignorance, its the truth! PLEASE, call Dave in the mourning and ask him what Cartridge is in a BR580. It will lend all of this.
Have you ever been told not to believe everything you hear on the net? If you can comprehend the fact that a GT40 has a 65mm comp wheel and a 35 has a 61mm, then how do you still believe that the said turbo's TRULY have a GT40 comp section?!
http://www.slowmotionmotorsports.com/mo ... hp?lid=157
Off the shelf GT40
http://www.shearermotorsport.com/galler ... rget6.html
Another Gt40 on a Manni built at the shop
http://www.revhard.com/s2000-turbo-kit/gt35-t.jpg
Off the shelf gt35
http://www.shearermotorsport.com/galler ... rget5.html
And another with an unported cover.
Do you see any difference lol? Is that enough reality for you? thats enough for me I have a headache now
Call Dave in the mourning and ask him what cartridge the BR580 (which is exactly the same as the AGP61, SC61, SCM61)is filled with. I am done.
If you still can not make heads or tails of it, believe what you want. I only serve to educate.
Current
08 535ix 420awhp
PostPosted: Wed Oct 26, 2005 1:21 am
Off the shelf GT40
Off the shelf gt35
No offense but I don't understand the argument anymore, lol. I mean, we both agree that the GT40 turbo uses a 65mm inducer comp wheel, and we both agree that the gt35r,sc61, br580, run 61mm inducer wheels. Is the argument the fact that the 35r, br580, and sc61 don't have gt40 compressor wheels? Cause the gt40 turbo and the gt35r, sc61, br580, agp61 all use a compressor wheel of the same family, the gt40 family. The trims and sizes are different of course between the gt35r and gt40 turbo but that wheels they use are still the gt40 comp wheel family.
PostPosted: Wed Oct 26, 2005 1:35 am
Compressor Specs:
Turbine Specs:
Compressor Specs
Turbine Specs
two different naming schemes genious. we don't name compressor wheels by the turbine they are attached to. they have their own individual naming. the complete turbo assembly is named after the turbine wheel, for what reason i do not know, it makes more sense in my opinion to name after the compressor wheel. the "GT40" designation is NOT in reference to what complete turbo assembly it belongs to, but rather an individual wheel name designation. the "GT35R" is the GT40 compressor wheel mated with a GT35 turbine wheel and GT30 series ball bearing center cartridge
Dave
90 AWD - 10.0 @ 139mph - weekend moneypit
91 AWD - Daily moneypit
89 Colt 1.5l - MPG Mobile
PostPosted: Wed Oct 26, 2005 3:37 am
So your sayign the GT35r and the GT40r have the same compressor wheel??!!? :rolleyes:
WTF I give up. You guys believe what you will. I obviously do nto knwo what I am talking about even though I sell no less than 2-3 GT series turbos A WEEK.
Current
08 535ix 420awhp
PostPosted: Wed Oct 26, 2005 11:39 am
re-read what i said it'll make sense if you read it enough. the wheels are named independently. i don't think it can get much clearer than that.
Dave
PostPosted: Wed Oct 26, 2005 2:14 pm
No, we are saying that they have what is called a "gt40" compressor wheel, but the wheels are different sizes between the gt35r and gt40r turbos. Its the same family of wheels but they have different sizes, and since its the same family its referred to by one name, GT40. I can't help it that garrett is retarded and named the wheels the same even though they are different sizes but its the facts.
PostPosted: Wed Oct 26, 2005 3:18 pm
it'sa common issue. Mitsubishi does the same shit with housings and wheels. same name can be two different things depending what part you're talking about. i personally didn't think it was taht difficult to grasp though. you have to look at the turbo not as a complete unit but as a combination of smaller units. like legos.
Dave
PostPosted: Thu Oct 27, 2005 11:59 am
Vendor
yea yea yea who can afford all that ball bearing mumbo jumbo anyways, lol.
boostfreak, just a quick question if you don't mind: why did you go with the 93+ dodge colt versus the 89-92? the wheel base looks to be a little longer which would definatly help but is there any other advantage? like what is the weight difference? thanks!
PostPosted: Thu Oct 27, 2005 3:21 pm
well i don't want to speak for him or anything, but it might have just been what was on hand for him... personally if i had the chance, i'd go for the 5g mirage and do a full evo conversion to it :twisted:
PostPosted: Thu Oct 27, 2005 3:44 pm
it'sa common issue. Mitsubishi does the same $%# with housings and wheels. same name can be two different things depending what part you're talking about. i personally didn't think it was taht difficult to grasp though. you have to look at the turbo not as a complete unit but as a combination of smaller units. like legos.
Give me an exaple then, becuase off the top, I dont agree.
There is only 1 type of comp wheel in a 14b
" " " " small 16g
" " " " " big 16g
" " " " 20g
" " " " " 13b
" " " " " 25g
There is no varient turbine wheel that you can call a tdo5 turbine
" " " " " tdo6 turbine
I can go on?
Current
08 535ix 420awhp
