It is currently Sun Nov 02, 2025 9:00 am
 Post subject: Blown Head Gasket!!!
PostPosted: Sat Oct 22, 2005 7:55 pm
Well, after swapping in a stock 4G63T and going through all the California smog BS it was finally time to bolt on some power! I just installed an EVO3 16G, 3" downpipe, 650cc injectors, EVO8 Maf and an Eprom ECU w/DSM link. It fired right up and ran like a champ, until I stoped at a light and noticed it was running a little rough. It runs but it's blowing a ton of white smoke, not good! When I got home I noticed the boost reference line coming off the turbo had popped off. I don't have a boost gauge yet so I had no idea. Oh well, time to pull the head. It seems like I'm always doing something to this thing!
PostPosted: Sat Oct 22, 2005 9:18 pm
Humm $1500 dollars in Mods and don't have a $50 boost gauge---
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
"Just like in the old days-More Horse Power means more crap to pick up-lol"
PostPosted: Sat Oct 22, 2005 9:30 pm
Yeah, I know. I havn't installed the boost controller yet so I figured it would be fine. Go ahead and rub it in!
PostPosted: Sun Oct 23, 2005 1:06 am
white smoke? how about a valve job? try out a compression test and a leak down test before you yank anything out
PostPosted: Sun Oct 23, 2005 12:16 pm
4g61t Delinquent
do a compression test first. my turbo Colt blew white smoke from grenaded pistons and rings.
I own a CSM.
PostPosted: Sun Oct 23, 2005 12:27 pm
What does the smoke smell like? My car blew out white smoke when I was pushing oil past the turbine seal of the turbo, but it smelled like gas. Also, if you had a blown HG it would most likely push coolant under boost. If you have milky color oil then you have a badly blown HG, if you are just pushing coolant under boost then its just leaking slightly under boost.
1999 Ford Contour SVT
PostPosted: Sun Oct 23, 2005 11:47 pm
Thanks for the tips guys. The smoke smells sweet, it seems like it's burning coolant. I just checked the oil though and it isn't milky at all. Also when I looked under the hood the dipstick was out and there was oil blown out on that side of the engine compartment. That sucks! I guess it could also be the piston rings? Stupid question but how would a compression test determine if it's the HG or the piston rings? Maybe this post should be moved to the tech section.
PostPosted: Mon Oct 24, 2005 1:10 am
ok, if it's white and sweet, then that's definitly coolant... just a heads up.
