It is currently Sun May 05, 2024 5:41 am
PostPosted: Sat Oct 08, 2005 12:06 pm
MITSUBISHI GALANT HG & HH (2.0L DOHC Engine) 1989 - 92 Engine Management System
ECM
The ECM is located behind the Left Hand Kick Panel.
ECM Voltage Table
Connector '1 to 24'
Pin # Circuit and Status.......................................... Voltage
1 Diagnostic Connector
Fault Code Output - Terminal 1
Diagnostic Connector Grounded........................ Low Volts
2 Diagnostic Connector
Idle Speed Disable - Terminal 10
4 Oxygen Sensor Signal
Engine Warm
Engine Running at 2000 RPM........................... 0.2 to 0.8 Volts
Normal Signal around 0.5 Volts
Normally fluctuates 7 to 8 times in 10 Seconds
5 Power Steering Switch
Ignition ON
Steering Wheel at Rest.................................... Battery Volts
Steering Wheel turned from Rest Position.......... Low Volts
6 Idle Switch
SOHC
Ignition ON
Throttle at Rest Position................................... Low Volts
Throttle Open.................................................. 5 Volts
7 Air Conditioner ON Request Signal
Signal meets ON Specifications........................ Low Volts
Signal does not meet ON Specifications............ 0 Volts
8 Air Mass Meter
Air Charge Temperature Sensor Output
Ignition ON
Air Temperature @ 20° C.
Engine Running............................................... 4 to 5 Volts
Voltage Output Decreases with Increase in Temperature
10 Air Mass Meter - Air Flow Sensor Signal
Ignition ON...................................................... 5 Volts
Engine Running at Idle..................................... Digital Signal (30 to 46 Hz)
Engine Running at 2000 RPM........................... Digital Signal (62 to 82 Hz)
12 Spark Advance Disable Connector
Connector NOT Grounded................................. 5 Volts
Connector Grounded........................................ Low Volts
13 Fuel Pump Supply Volts Monitor
Fuel Pump running........................................... Low Volts
14 Idle Switch
Ignition ON
Throttle Open.................................................. Battery Volts
16 Air Mass Meter
Barometric Air Pressure (BAP) Sensor Output
Ignition ON
BAP of 103 kPa Approx. (Sea Level)................. 4 Volts Approx.
17 Sensor Ground
Ignition ON / OFF............................................ 0 Volts
18 Vehicle Speed Sensor
Ignition ON...................................................... Low or 5 Volts
Engine Running............................................... Digital Signal
5 Volts Square Wave
Oscilloscope pattern
19 Throttle Position Sensor Output Signal
Ignition ON
Throttle at Rest................................................ 0.48 to 0.52 Volts
Throttle Fully Open.......................................... 4.8 to 5.2 Volts
20 Engine Coolant Temperature Sensor
Ignition ON
Engine Cold.................................................... 2 to 3 Volts
Engine Warm.................................................. Approx. 1 Volts
21 Crank Angle Sensor
5 Volts Square Wave
22 # 1 Cylinder TDC Sensor
5 Volts Square Wave
23 ECM 5 Volts Output
24 Sensor Ground
Connector '51 to 68'
51 Injector Ground
Ignition ON..................................................... Battery Volts
52 Injector Ground
54 Coil Switching Power Transistor
Engine Cranking or running............................... Digital Signal
55 Coil Switching Power Transistor
Engine cranking or running............................... Digital Signal
56 Control Relay Ground
Control Relay Energised................................... Low Volts
58 Idle Speed Control Motor
Ignition ON...................................................... Battery Volts
Engine Running............................................... Low Volts Pulses
59 Idle Speed Control Motor
60 Injector Ground
61 Injector Ground
63 Control Relay Ground
64 Engine Checklight Ground
Engine Running
Checklight OFF............................................... Battery Volts
65 Air Conditioner Relay Coil Ground
Relay Energised.............................................. Low Volts
66 Control Relay Ground
67 Idle Speed Control Motor
68 Idle Speed Control Motor
Connector '101 to 110'
101 ECM Ground
102 ECM Supply Volts
Control Relay Energised................................... Battery Volts
103 ECM Supply Volts Permanent RAM supply
Ignition ON / OFF............................................ Battery Volts
104 ECM Ground
Manual Transmission
104 Start Signal
Automatic Transmission
Engine Cranking.............................................. Battery Volts
105 Oxygen Sensor Heater Ground
Heater ON...................................................... Low Volts
Heater OFF..................................................... Battery Volts
106 ECM Ground
107 Supply Volts for ECM / Sensors
108 Start Signal
Manual Transmission
108 Neutral / Drive Switch
Ignition ON
Park or Neutral Selected.................................. Low Volts
Any Other Gear Selected................................. Battery Volts
109 Coil Switching Power Transistor
110 ECM Supply Volts
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
