It is currently Sun Apr 28, 2024 6:04 am
PostPosted: Fri Oct 07, 2005 6:55 pm
MITSUBISHI LANCER CA & CB 1.5L (4G15 Engine), Cyborg, CSM 1988-92 Engine Management System
ECM
The ECM is located behind the Left Hand Kick Panel for RHD (Right hand in North America for LHD).
ECM Voltage Table
1 to 24 Connector
Pin # Circuit and Status......................................... Voltage
1 Diagnostic Connector Fault Code Output
Terminal 1
Diagnostic Connector Grounded........................ Low Volts
2 Diagnostic Connector Idle Speed Disable
Terminal 10
4 Oxygen Sensor Signal
Engine Warm
Engine Running.............................................. 0.2 to 0.8 Volts
Normal Signal................................................ 0.5 Volts Approx.
Normally fluctuates 7 to 8 times in 10 Seconds
5 Power Steering Switch
Ignition ON
Steering wheel at rest...................................... Battery Volts
Steering wheel turned from rest position............ Low Volts
6 Idle Switch
(Inside Motor Position Sensor)
Ignition ON
Throttle at rest position.................................... Low Volts
Throttle open................................................... Battery Volts
7 A/C On Request Signal
Signal meets ON specifications........................ Low Volts
Signal does not meet ON specifications............ 0 Volts
8 Air Mass Meter
Air Charge Temperature Sensor Output
Ignition ON
Air Temperature @ 20° C
Engine Running............................................... 4 to 5 Volts
Voltage Output Decreases with Increase in Temperature.
10 Air Mass Meter Air Flow Sensor Output
Ignition ON...................................................... 5 Volts
Engine Running.............................................. Digital Signal
Output Signal Increases in Frequency with Increase in Air Flow.
12 Spark Advance Disable Connector
Connector NOT Grounded................................ 5 Volts
Connector Grounded........................................ Low Volts
13 ECM 5 Volt Output
Ignition ON..................................................... 5 Volts
14 Sensor Ground
Ignition ON / OFF........................................... 0 Volts
16 Air Mass Meter
Barometric Air Pressure Sensor Output
Ignition ON
BAP approximately 103 kPa (Sea level)............ 4 Volts Approx.
17 Motor Position Sensor Output Signal
Ignition ON
Dependant on ISC servo motor position............. Up to 5 Volts
18 Vehicle Speed Sensor
Ignition ON...................................................... Low or 5 Volts
Engine Running............................................... Digital Signal
5 Volt square wave
Oscilloscope Pattern
19 Throttle Position Sensor Output Signal
Ignition ON
Throttle at rest................................................. 0.48 to 0.52 Volts
Throttle fully open............................................ 4.8 to 5.2 Volts
20 Engine Coolant Temperature Sensor
Ignition ON
Engine Cold.................................................... 2 to 3 Volts
Engine Warm.................................................. Approx. 1 Volt
21 Crank Angle Sensor
Engine Cranking or Running............................. Digital Signal
5 Volt square wave
22 # 1 Cylinder TDC Sensor
5 Volt square wave
23 ECM 5 Volt Output
24 Sensor Ground
Ignition ON / OFF............................................ 0 Volts
51 to 68 Connector
51 Injector Ground
Ignition ON.................................................... Battery Volts
52 Injector Ground
Ignition ON..................................................... Battery Volts
54 Coil Switching Power Transistor
Engine cranking or running............................... Digital signal
56 Control Relay Ground
Control relay energised.................................... Low Volts
58 Idle Speed Control Motor
Engine running................................................ Low volt pulses
59 Idle Speed Control Motor
Engine running................................................ Low Volt pulses
60 Injector Ground
61 Injector Ground
62 Canister Purge (If Fitted)
Ignition ON
Engine OFF.................................................... Battery Volts
64 Engine Checklight Ground
Engine Running
Engine Checklight OFF................................... Battery Volts
65 A/C Relay Coil Ground
Relay energised.............................................. Low Volts
101 to 110 Connector
101 ECM Ground
102 ECM Supply Volts
Control relay energised.................................... Battery Volts
103 ECM Supply Volts Permanent RAM Supply
Ignition ON / OFF............................................ Battery Volts
104 ECM Ground
Manual Transmission
104 Neutral / Drive Signal
Automatic Transmission
Ignition ON
Park or Neutral Selected................................. Low Volts
Any Other Gears Selected.............................. Battery Volts
106 ECM Ground
107 Supply Volts for ECM / Sensors
108 Start Signal
Manual Transmission
Engine cranking.............................................. Battery Volts
108 Neutral / Drive Signal
Ignition ON
109 Fuel Pump Voltage Supply Monitor
Fuel Pump Running......................................... Low Volts
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
