It is currently Tue Apr 23, 2024 1:53 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Wed Nov 24, 2004 12:55 am
i left every thing as is the cables are from a 1.5 89 colt 4 speed and the tranny is from a 90 eclipse and to make note where you bolt the linkageon the trannyor excuse me the shifter cable bracket i only used one screw to mount not two .. icantake pics if needed
http://www.clubgp.com/newforum/upfiles/ ... d93156.gif
PostPosted: Wed Nov 24, 2004 10:01 pm
I purchased the part today from Home Dept for $1.26. Works beautiful!! Now the person that had the car before me tried to weld the selector arm some kind of way and the selector arm broke off. He didn't know about the 2inch extension needed. Which selector are you using. Keep in mind that I have a 4g63t motor&tranny swap in a 1.6T body. Im looking for a selector I just don't know which oneis needed. You have been a great help BD Mitsu.
PostPosted: Thu Nov 25, 2004 10:42 pm
i had a 1.5 4-spped colt swapped with a 90 eclipse turbo tranny and engine. changed nothing the cables are factory for the vehicle
PostPosted: Wed Sep 14, 2005 11:31 pm
Bd Mitsu, could you please send me the pictures of the 1G Km210 turnbuckle shift lever option... Thanks!!!!
waxie1@hotmail.com
90 4G63BT LANCER GSR Cyborg, 14b, KM206, Xtreme XHD Clutch
92 4G61 LANCER GSR
Speed Thrills, Hesitation Kills!!!
PostPosted: Sat Sep 17, 2005 1:06 pm
And for all that would need this... ive doone the digging.. found the dvd.. and here it is :finga:
PostPosted: Mon Sep 19, 2005 7:08 am
THA'S THE $HIT RIGHT THERE!!!
would have NEVER thought bout that option..makes complete sense!
now..what is the CORRECT name for it (the part) and is there a specific size to ask for?
hardware part?
PostPosted: Tue Sep 27, 2005 6:59 am
ok..i am gettin some turn buckles but they were too small (threading)
can someone confirm the thread/bolt size please. and if a 3" turnbuckle will work..the 2" is too small.
thanks
8)
PostPosted: Tue Sep 27, 2005 8:26 pm
Get a small block of aluminum and tap it with normal thread direction and pitch on one side to match the cable's bolt threads and do reverse threading on the other side; this way you can make it any size you want. :o 8)
PostPosted: Tue Sep 27, 2005 8:32 pm
BD,
I'll host that linkage pic for you email it to berserko@heckatomb.com
LC '01 Accent GSI - Silver
PostPosted: Tue Sep 27, 2005 11:28 pm
So this mod enables you to use the stock shifter cables for the 1.5 tranny correct? Also you don't have to change out the shift levers in the tranny or whatever they are called? If so I vote we move this to the archives!
 Post subject: Re: Shift linkage!
PostPosted: Fri Jan 08, 2010 10:34 pm
Added the pics back to the archives for now.
