It is currently Sat Jun 15, 2024 3:20 pm
 Post subject: lsd in drag race
PostPosted: Sat Jul 09, 2005 12:33 am
there's this argument on running lsd for DRAG RACING
guy 1; running front wheel drive with big power and without lsd is good. the power is instant.
guy 2; running front wheel with big power and lsd is good. gives equal power to both wheels.
does running without lsd is good for drag? any input guys?
PostPosted: Sat Jul 09, 2005 5:33 am
You'll want an LSD for launching. Even at stock power levels it will make a difference. Also, your tranny and axles will live longer. :D
Got rabies?
PostPosted: Sun Jul 10, 2005 2:11 am
I would agree that it is not neccessary based on experience. When I started making a lot of power in my Omni both tires seem to spin about the same off the line.
Also, If your car is well balanced it won't matter for drag racing. For example you can preload your suspension or add weight over the tire that has a tendency to spin. Turbododge guys (2.2,2.5 turbo cars) add an air shock to the passenger side rear and/or put a block of wood between the sway bar and the K frame to preload the suspension.
84 Colt GTS 4g63 (11.58 121mph)
85 Dodge Omni GLH-t (11.98 117mph)
70 Cuda (getting 2jz or twin turbos?)
90 Dodge Caravan 2.5 turbo (14.1 100mph w/slipping clutch)
PostPosted: Sun Jul 10, 2005 11:11 pm
You will be a one wheel wonder if you make big power period, imo big power is 500 plus WHP. a LSD IMO is a must.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
"Just like in the old days-More Horse Power means more crap to pick up-lol"
PostPosted: Mon Jul 11, 2005 1:04 pm
on our colt with an evo16g at 21ish psi would walk 3rg gear all over the road with 225 series tires, now with a sleeper 16g(20g guts) and a sbr lsd it doesnt walk near as bad at 18psi.
PostPosted: Mon Jul 11, 2005 2:43 pm
"Without LSD the power is instant"
Do you think the LSD has to spool up or something? Does he think it's a torque converter or what? :x
PostPosted: Tue Jul 12, 2005 2:41 pm
Exactly like that. Your LSD trip has to spool up before you get insane. :lol:
Edit: I just couldn't resist pulling that pun. :D
Got rabies?
PostPosted: Wed Jul 13, 2005 1:58 pm
do you like that sleeper 20g over the evo3 turbo?
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Wed Jul 13, 2005 2:43 pm
BANNED FOR FRAUD
Jason Veraldi
Scammer
PostPosted: Thu Jul 14, 2005 12:37 pm
i love it, ,it looks like a 14b, spools a bit slower than the 16g, is ALOT louder, and is more streetable, we can really hammer 2nd gear now with the lsd and this turbo due to slower spool, it doesn't just spin them like mad. a bigger exhuast is in the works to take full advantage of more airflow.
and the efficiency range of the turbo starts at 17-18ish psi, so as boost is clibing, it is like a light switch, "on" when boost climbs up there.
PostPosted: Thu Jul 14, 2005 2:46 pm
peg leg burnouts pwn
PostPosted: Thu Jul 14, 2005 2:56 pm
yeah most mitsu turbos are like an off/on switch :)
it is tempting - would be a LOT of fun for me to slap on that turbo and head out to our local getogethers - everyone knows i am rocking a 14b no one would notice :twisted:
90 GGSX
89 YX-600
92 Laser AWD
