It is currently Sun Jun 16, 2024 10:56 pm
 Post subject: Engine IN Harness IN
PostPosted: Thu Jul 07, 2005 12:06 am
Ok this is as basic as it come I have my 1993 colt ... It now has the 4g63t installed and a 1990 ecu and wiring harness in place and plugged into everything under the hood..... The triple fuse block is connected to the battery... Now I just want the car to run basically ... So what wires do I have to run? Just an ignition wire to the ignition wire on the MPI relay? and then another splice from the fuel sender MPI wire to the positive on the fuel fump? Then it should run? Or is there another.. I have looked through all the swap posts and just want a confirmation on this .. Thanks a lot I appreciate all the hard work!
PostPosted: Thu Jul 07, 2005 1:36 pm
http://www.4g61t.org/phpBB2/viewtopic.php?t=14412
under mods/1.5/engine/wireing
this is for 89-92 csms so i dont know itf ittl be much help, but hey here you go
4g61t.com
PostPosted: Thu Jul 07, 2005 1:41 pm
You may also look to http://mirageforums.net as non of us have done this swap into a 93.
4g61t.com
