It is currently Wed Jun 05, 2024 5:17 pm
 Post subject: My engine rebuilt
PostPosted: Sat Feb 11, 2012 12:26 pm
Hi,
Last november i had a big issue, i broke the timing belt and i had to replace my engine. One guy has a 4g63t block in good shape, it has the balance shaft remove, evo 8 pistons with totalseal gapless rings. I spend about $1000 to get the engine working. But I m very consearn about the total seal gapless rings, by now i had 3000 miles with the engine and sometimes i have a lot of smoke, but i `m not sure if my turbo is ok.
Anyway I want to share some pics to you, and i have a cuestion with the last pic. I`ll install a manual boost controler. I put a screw in the hole marked with the circle but in looking for information on the web and i think this the place to install the boost controller conectet to the wastegale Am i right?
MY BROKE ENGINE
WORKING
HEAD
NEW ENGINE WITH A NEW VALVE COVER
SARD FPR, ALSO A FRONT STRUNTBAR
DEPO DIGITAL FP METER
CHEAP TURBOTIMER
JUST A NICE PIC
 Post subject: Re: My engine rebuilt
PostPosted: Sat Feb 11, 2012 1:04 pm
last pic.. the stock water line has a mounting bracket that gets bolted there..
PostPosted: Mon Feb 13, 2012 7:48 am
Thanks, It must be eassy for you guys but i´m cluless .... Where do i take the line from the turbo? i thought it should be that...
I google it but i don´t know where to take the line on the turbo... :oops: sorry...
