It is currently Tue May 21, 2024 7:51 pm
 Post subject: xjokux - Red JDM GSR
PostPosted: Thu Dec 08, 2011 2:19 am
Hi, I haven't really introduce my myself - long time reading few times poster. I'm Johno from the land of Oz.
Here is my build.
91 CB Lancer GSR Fwd
Goal turn it into a JDM car (Looks & performance wise
Engine:
Vr4 4g63T 6-bolt motor
SS Driven Performance w/ external gate (heat wrapped)
2.5' - 3' Exhaust w/ high flow cat
4g61 Inlet manifold
560cc Evo 7 J-spec injector
Evo III Big 16g turbo
Braided turbo oil line
Cusco oil catch can
Evo 6 Intercooler 2.5' piping
Tial 38mm wastegate
ARP headstud & rod bolts
Fidanza adjustable cam gears (red)
Ferra competition plus valves (stock size)
Cometic headgasket 1.6mm
Wiseco 8.3.1 pistons
Manley H-beam rods
OEM knock sensor
ACL race 'Tri-Metal' rod & main bearings
Balance shaft eliminator
SS 7CM Turbo to Manifold Gasket
[2x] SS 38mm Wastegate Gasket
Magnus Heat Intake Manifold Gasket
[2x] OEM Oil Return Line Gasket
OEM O2 Housing Gasket EVO III
HKS Fine Tune Timing Belt
Head - shimmed, vaccum tested
Block - Hone & balanced
055 maf sensor w/ k&n pod filter
O2 sensor
BC 280 cams w/ springs & retainers
J-spec 808 ecu - ecmlink
60mm throttle body
Vr4 gearbox welded
Exedy HD clutch
Fidanza Lighten flywheel
Ross 'Metal Jacket' race harmonic balancer
All-round polythane rubber mounts
Honda radiator
SUPENSION
15' Sprint hart rims light weight (7' +50 & 6.5' +45)
Evo IV calipers
Hells braided line (front & rears)
Dba 4000 series crossdrilled rotors (294mm)
Ferodo DS performance FDS765
1' master cylinder
Custom 23mm front swaybar
Whiteline 23mm adjustable rear swaybar
Front strut brace
Rear strut brace
Whiteline pan-hard rod
Evo offset caster bushes
Custom fulcrum coilover w/ koni inserts
Brigdestone adrenaline re001 195/50/15
Nakang ultra sport 205/50/15
Front Lip
100mm Front splitter & underbody shield
ACCESSORIES
Blitz turbo timer
Greddy dual boost controller
Evo 9 gauges
52mm Boost gauge
Red LED dial
Evo recaro front seats
Red LED console
Engine bay painted
Tinted windows
LED parker lights
Custom grille
Painted rocker cover
CC coupe shifter
LED under-bonnet light
Image Image
Image Image
If anyone is keen on more photos I have them throughout the build of this car :) and will update this regularly. Atm I'm in the process of rebuilding the engine so most of the internals haven't been installed yet as funds are low for block/head machining - after a long list of parts order.
Image Image Image Image
How she stands now
Image Image Image
 Post subject: Re: xjokux - Red JDM GSR
PostPosted: Thu Dec 08, 2011 10:37 am
Heck yeah we are keen on more photos, keep them coming.
PostPosted: Thu Dec 08, 2011 10:38 am
Welcome to the forum! Allow me the 2nd the more photos. MUCH more!
PostPosted: Fri Dec 09, 2011 5:04 am
Awesome - I knew I should of started a build here along with other forums.
I'll just post a few more modification photos.
Image Image Image
BTW THIS WAS HOW I GOT THE CAR $400
PostPosted: Fri Dec 09, 2011 9:16 am
Wow, is that caliper clearing the rim? Looks really close.
PostPosted: Sat Dec 10, 2011 2:30 am
I wish we had gotten the 4door hatches here. Would make a great awd car.
PostPosted: Mon Dec 12, 2011 1:28 am
Yea it is. vr4 calipers sits closer to the centre of the hub as the evo 4 are further out. I had to grind maybe 1-2mm since it was touching but it has 2-3mm clearance inside of the rim.
Awd models are really rare here in Oz maybe 10 or so exist and importing is just ridiculously expensive. There have been a few for sale but all of them have the 2L conversion and the price for them is steep!
PostPosted: Sat Jan 28, 2012 6:14 am
Time for update!
I've finally re built my ages quite a awhile again actually tuning was a time consumer and waiting for parts.
So now I'm running
Genuine big 16g flapper welded for external gate
Fidzana adjust. cam gears
Arp headstuds & 1.6 comestic gasket
Ferrea comp stock sized valves & BC 280cams
Forged internals - Weisco piston (8.3.1) & Manley h-beams
ACL Race tri bearings
Magnus heat barrier gasket
HKS timing belt
Clear cam cover
Balance shaft removed
Ecmlink
Lc1 innovate wideband
Re doing the timing as bad to fix the markings, I didnt have to drop the engine thank god but I had to remove both side mounts, disconnect IC piping, remove maf sensor and the usual rest. With a bit of a wiggle here and there I got the timing cover off as well the harmonic by tilting the engine.
I thought a had a vacuum leak but I think it was the timing that made tuning the idle very difficult! Idles way better than any before and steady. I'm not running rich either so the wideband states 13:1 - 15:1 on idle I think.
Just need to bleed the brakes and clutch and go for a spin. Im yet to test the coilovers and a few suspension mods added like coilovers, after-makert pan-hard rod and rear strut brace.
Im just content now that I'm getting progress and not one problem after another *knocks on wood* as you do.
Couple of photos before engine implant - half polish intake manifold as I got lazy and painted the rest black. Never again...
and how it is now + a video. I'm loving the lumpy sound though I think chuck the muffler and stick a canon instead.
Still yet to experience drive from complete make over from now to before.
Image Image
Image Image
http://www.youtube.com/watch?v=_EfxkUo1 ... e=youtu.be
PostPosted: Mon Jan 30, 2012 4:23 am
Looks awesome! keep it up
My feedback thread:
PostPosted: Tue Jan 31, 2012 9:42 pm
What lip is that?
PostPosted: Mon Feb 13, 2012 6:58 am
Came off a stock model with the 1.5 efi engine.
From what I know it was to make the bumper look lower to match the gsr bumper. It is also short 50mm each end when mounting it - easily fixed problem
