It is currently Fri May 03, 2024 12:39 am
PostPosted: Thu Feb 10, 2011 5:03 am
Hey everyone! Just swiped this car from my neighbor for 500... it sat for over a year, started right up and passed emissions no problem! Bare bones, completely stock 5 speed Fuel injected.
Car had 188,oookms when bought, put 3000kms since
Recent work;
Timing belt
Water pump
All fluids changed
Spark plugs
Breaks
Rear bearings
So this car does have a few problems...
When its cold, the tranny shifts hard in reverse, 1st and 2nd(sometimes I roll to a stop trying to get it into 2nd) LOL Tranny is just notchy in general... hoping clutch will fix it.
Something makes clunking noise when turning steering wheel when not moving (or turning hard)
Right rear shock rusted out
Ticking noise from engine when warm (possibly from setting valve when cold?)
Oh and climate control only works on last two speeds...
PostPosted: Thu Feb 10, 2011 10:40 am
Looks to be in good condition but that's not a 92. Still a good pick up for $500.
PostPosted: Thu Feb 10, 2011 11:00 am
Is the clutch hydraulically actuated or cable? The ticking sound is probably valve adjustment. If that engine has manually adjustable rocker arms you can pull the valve cover and adjust them back to factory specifications. If it has hydraulically adjusted lifters then you will need new lifters. The clunking can be bad tie rod ends or bad steering rack mounts. Inspection will let you know which is true in that regard.
The car looks clean and for $500 you can't beat it.
PostPosted: Thu Feb 10, 2011 11:59 pm
Excuse me fastvtgsx, I think i know what year my car is... This car is from Canada, maybe thats why you think it isn't 92? And thanks CSM Shawn, the clutch is hydraulically actuated, and I think the clunking is probably the steering rack mounts, as it only happens when really cold and usually steering at slow (like really slow) speeds. Thanks for replies...
PostPosted: Fri Feb 11, 2011 9:33 am
I would bleed the clutch actuation system and inspect the master and slave for leaks before going for a clutch replacement.
PostPosted: Fri Feb 11, 2011 11:45 am
It's the old body style that was replaced by the 6th gen colt's in 89, that's why I don't think it's a 92. Unless Canada decided to stick you guys with the old version for 3 extra years which is quite odd.
http://en.wikipedia.org/wiki/Dodge_Colt
PostPosted: Fri Feb 11, 2011 2:02 pm
Well, all I know is that I never see this car... All the ones I see are made in the 80's. This car is a 92, maybe It was the last of its kind, and got labelled as a 92. All i know is that its Aircared (emissions) for 2 years, and only 92-newer can have 2 years Aircare.
And CSM Shawn, I've already bled the clutch system, and put new gear oil in it. I don't know why the gears are so choppy, I'm thinking its because the clutch is original from 92. Could also be the linkage?
PostPosted: Fri Feb 11, 2011 11:24 pm
Its definitely a 92. Research has proven that they had both body styles available.
Wiki is essentially useless as it can be edited by almost anyone without any knowledge or proof to back it up.
Welcome to 4g61t. Enjoy your stay! :)
-Shawn
MEMBER #1495
'92 Dodge Colt 63 swap (SOLD)
'92 Galant VR-4 (it's Alive!!)
'12 Forester (DD)
GONE:
'92 Plymouth Colt 12v 4M->5M
'90 Dodge Colt GL 8v 3A
'89 Plymouth Colt 8v 5M
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
PostPosted: Fri Feb 18, 2011 2:05 am
yeah up here in British Columbia i have seen 1992 2G colts all the time. they sold quite a few of them. They came with 1.5L 12V engines...
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Fri Feb 18, 2011 8:38 am
It could be the linkage. Colt shifter bases are known for getting very sloppy with age.
