Optical Phenom BUILD! http://4g61t.org/forum/viewtopic.php?f=9&t=32083 |
Author: | Optical Phenomenon [ Mon Mar 29, 2010 2:15 pm ] |
Post subject: | Optical Phenom BUILD! |
Intentions have been from the start to swap this thing. Now that i have a driver i am knee deep into it and hoping to get it close to running this weekend! I am just swapping a stock drive train for now until i have more $$$ and time. Alright so Parts list is the first thing i guess you guys need: 91 Mirage 1.5 car 5 speed very clean chassis and interior 140k when i got the car. 90 Laser parts car running and driving with a bad 14b ![]() Motor Parts: Full 1.6 gt mount setup Urethane replacements front and rear and urethane filled upper and trans (i filled those) t25 in good shape Magnus SMIM (cracked and re-welded BOUGHT CHEAP) SBR cast mani Megan racing external gate (came with the manifold) ![]() ![]() Transmission: Stock with gt axles and half shaft Suspension: Megan racing full coilover setup modified (the car to fit these, check out the thread for pics) ![]() Brakes (Front): Elantra booster and master as well a Prop valve Galant VR4 hubs Galant VR4 Calipers Galant VR4 Slotted rotors and ceramic pads Galant VR4 Stainless braided encased in black plastic coating! (Rear): Gt rear disk setup Slotted GVR4 rotors and ceramic pads Exhaust: 3" mandrel 2g awd DP The rest will be 3" custom made Wheels: Oz rally wheels (200 with tires! Stole them from a local guy) Interior: gt 9k tach will be modifying DC2 integra seats to fit... ![]() Wiring: Tore the 90 harness apart and modified the Shat out of it! Made my own jumper harness based on the idea of 89mirageman and using alldata, mitchell, and the archives ![]() Also made a jumper harness for my cd player out of the original radio ![]() ![]() AND NOW PICTURES! Thanks Goes to: Andrew All the locals Robb, Mr2Guru and all the other cool car guys local in WNC! Lusion972 for the mounts, SMIM, axles 89Mirageman Elantra brake stuff Anyone else i forgot to mention i bought parts from Speak Up and be recognized |
Author: | Red Sleeper [ Mon Mar 29, 2010 6:13 pm ] |
Post subject: | Re: Optical Phenom BUILD! |
That car looks CLEAN!! I'd use the stock DSM intake manifold untill you upgrad turbos.. I had a magnus when i first built my black colt and it was the worst mod i did. UNTILL i put a big turbo on the car. It just made it real laggy.. I had 450s/eIII 16g/MAFT |
Author: | Optical Phenomenon [ Mon Mar 29, 2010 9:50 pm ] |
I am expecting some lag yeah but i have plans REALLY SOON for a bigger turbo so i think i'll be able to handle it for a little bit...and Thanks ![]() |
Author: | Optical Phenomenon [ Sun Apr 04, 2010 12:14 pm ] |
Update! ...my 3 days off working on this car were not even close to as productive as i thought they would be. However, i did manage to get a couple things done. So without further adieu here those pics are: As i will be running the T25 with external gate i thought i would close that dang flapper door ![]() I also thought that since i was going to put some brakes on this bad boy i would install the elantra booster, M/C, and prop valve. Here is a Before and After mock up: ![]() Figured i would put this in next... ![]() Little bit of brake: ![]() Some hubs ![]() Finished product: ![]() And last but not least some stainless braided with black plastic encapsulation: ![]() |
