I will try to get the pics up on it shortly but here is the mod lis
Mods:
Engine:
-6Bolt 2.3L
-4G64 Crank
-ARP Headstuds
-ARP Mainstuds
-ATI Super Harmonic Damper
-Manley Rods
-Wiseco 8.8:1 Pistons .020
Head:
-Crower Retainers
-DV/DT Coil On Plugs
-Fidanza Cam Gears
-Ferrea 1mm Oversized Valves
-HKS 272/272 Cams
-HKS Springs
-MLS Headgasket
-Power Enterprise Timing Belt
-Shaved Valve Cover
Turbo:
-Borg Warner S372
-DV/DT Fabrications 4" Turbo-Back Exhaust
-Shearer Fabrications T4 Top Mount Exhaust Manifold
-Twin TiAL 38mm MS-V Wastegates
Intake:
-DV/DT Fabrications FLP Intake Manifold
-DV/DT Fabrications Intercooler w/ 3" Piping
-DV/DT Fabrications 5" Intake Pipe
-Q45 Throttle Body
-70mm CNC Throttle Body
-Twin Tial 50mm Q Blow Off Valves
Drivetrain/Suspension:
-TRE/PPG Dogbox
-QM Twin Disc Clutch
-Cross Drilled and Slotted Rotors
-Eibach Lowering Springs
-KYB GR-2 Shocks
-Enkei RPF-1 SBC 17x8.5 +30mm Offset
-BFG g-force T/A KDW 2 235/40/17
Fuel:
-Twin DV/DT Fabrications Fuel Rails
-FIC 1600cc Injectors
-FIC 650cc Injectors
-Fuelab 515 Fuel Pressure Regulator
-Fuelab 818 Fuel Filter
-Magnafuel ProTuner 750 Fuel Pump 4303
-10AN Black Nylon Fuel Line
Electronics:
-AEM EMS
-AEM 5 Bar Map Sensor
-AEM AIT Sensor
-AEM Boost Control Solenoid
-AEM Wideband
-Defi Boost Gauge
-Defi Fuel Pressure Gauge
-Dyantek ARC-2 Ignition Box
Misc:
-Battery relocated to the trunk
-Blitz Turbo Timer
-Koyo Aluminum Radiator
-New Paint
-Prothane Motor Mounts
-Moroso Oil Catch Can
-A/C
-P/S
My friend which is not to smart bought the car drove it. spun a rod bearing in the motor. I picked this car up for a fraction of what it cost to build I mean that to
