It is currently Wed May 22, 2024 11:21 pm
PostPosted: Sun Jun 21, 2009 3:51 pm
Hello,
after reading on these side for nearly 6 month, now i try to introduce myself.
I´m a 20 year old guy from germany,and the proud owner of a rare Lancer AWD
It´s my first car, so it is something special to me.
The preownerns was a old woman, and later her grandchild.
When i bought it, there were only 152000km on the clock and a completly filled service check book.
After the buy i start to investigate about the car and the engine the 4G37.
It brings to the light, that there are only 143 of them driving in Germany :(
And some other aspects, which tells me, that these care is something special.
Over 15.000km on the road later and i was big fan, everything was perfect, execpt one thing is in need of improving => The power!!!
97PS are good for crusing, but not for enough for german highways (unlimited you rember :finga: ) and the the twisting countryside highway.
The improvement: TURBOCHARING!!!
About my turbo projekt i will wirte later.
Here some pictures from the current status of the car - nearly stock
At j2dapo, you had infected me with your fog light grill :)
PS: Sry, but i hadn`t be bothered to wash the car before i took the photos. :oops:
PostPosted: Sun Jun 21, 2009 6:43 pm
Thanks for introducing yourself. Sweet car! Post some underhood and interior pics.
PostPosted: Sun Jun 21, 2009 8:03 pm
Wow, lots of rare parts on that car! Welcome to 61t.org!
PostPosted: Mon Jun 22, 2009 2:15 am
Thanks.
Here some photos of the interiour:
You see, there is virtually everthing on electrical goddies present:
power windows, power sunroof, seat heating, electrical exterior mirror, central locking.
PostPosted: Mon Jun 22, 2009 2:27 am
The engine is stock!
I returned only the litte filter in the air intake (Don´t know the word at time)
and a few days ago i dislocated my batterie in the trunk, cause i need the place in the front for my turbo projekt.
PostPosted: Mon Jun 22, 2009 3:49 am
Wow, heated seats! never seen that before!
PostPosted: Mon Jun 22, 2009 9:37 am
you can grab a turbo from the previous generation mirage turbo's that had the g32b(if they were in germany), and it should be almost a direct swap.
PostPosted: Mon Jun 22, 2009 10:02 am
Cool car. Welcome to the Forums. Are those stock springs on it because it seems to have a very large wheel gap.
PostPosted: Mon Jun 22, 2009 12:30 pm
He already has those g32b parts :wink: (and I have the same fog light grill :finga: ). I can't wait to see what the 1.8L with a turbo will do. Post more pics up if you can, we want to see the rear sub frame.
Tim do you have any wiring schematics for the fog lights?
PostPosted: Mon Jun 22, 2009 2:12 pm
Yes there are stock C77 springs in it. They have a much higher spring rate than the springs in the other Lancer Versions (17,8-19,0 N/mm to 24N/mm in the C77). This difference in the rate is the reason for the large wheel gap.
As j2dapo wrote i have nearly all necessary parts right here (2 meters away)
The packet from canada :party1:
My "turbo-kit"
Oil-, Waterlines, Gaskets, the little TC04 Turbo, Bolts etc.
Only the intercooler, the BOV (1G) and the Air-intake things (hose, piping etc.) are not on the picture... They will follow...
Side note: These parts alltogether from canada, cause the G32b aka 4G32 was as far as i know only available in germany in a colt "C10" and they are very hard to find. So import the parts was easier 8)
About the wiring, i have a the mechanic manual on my PC, i will search about wiring.
(The fog lights on my car are not connected to the foglight switch. The are switched with the country beam.)
PostPosted: Wed Aug 05, 2009 4:08 pm
Since yesterday my car gets his improvment...
It`s like a dream... Every part from the 4G32t fits perfectly also the downpipe!!!!
Many parts are plug and play and the existing problems are snippy
There are only a few problems bye this project:
The $%&&&/-waterline behind the manifold clash with the compressorhousing so i had to cut it off and put in a siliconhose.
Finding a way for the airhose to turbo is nearly hard as hell, `cause its very tight there.
The biggest problem, at the moment is the oil pan its somewhere over the tranny, my idea was to remove the pan, mount a flange on and fix it.
I have no welding equipment so i cannot weld the flange on here in the garage. :( :(
I will look for a makeshift.
This is how i work in the garage of my parents... Their car have to wait outdoor :P
look at my beautiful makeshift for the air-filter-housing ^^
The result of 2 days of work :finga:
PostPosted: Wed Aug 05, 2009 7:08 pm
Nice work!
I like how u relocated the air can. I bet that a g32b water pipe and oil pan would have helped you, but we know what a hassle shipping to/from Canada is...
Keep up the good work and take more pictures.
PostPosted: Tue Aug 11, 2009 1:06 pm
Car is still running.... but not more :(
It lose water like a old man, at the waterpipe when water is hot and there is some pressure in the system :-? .
And there are some droplets of oil at the floor. Maybe from the oil return.
Tomorrow i will fix that 8)
Apart from these little problems... I`VE GOT A TURBOCAR!!! :supz:
With that incredible turbosound. :rolleyes:
More pictures:
This is how i looks now....
And i stupid idiot polished the manifold -.-
If anybody told me how fast it will be look like this - i hadn´t do that.
This was the polished manifold :cry:
And again.
My air-filter old/new
Aaaah, i forgot the original manifold:
Nice, isn`t it?
