It is currently Thu May 09, 2024 2:57 pm
 Post subject: AC install on 3g
PostPosted: Wed May 27, 2009 3:57 pm
I have a 92 dodge colt. I it was a 1.5 the car had ac. Now I swaped a 4g63 in it and bought a wire harness converter from this fourm and it is not wired for the ac. Does anyone have a guide on here on how to wire it up or any idea's or help would be nice. Also what as pump do I use and what ac bracket???
Thank you
Tyler,
 Post subject: Re: AC install on 3g
PostPosted: Wed May 27, 2009 4:56 pm
Check with Jason (lilevo) on the wiring dvd as I believe he explains this in it. I would think you would need the compressor and bracket from a 1.6 dohc car, 92-95 elantra stuff may work with some tweaking but I'm not sure.
PostPosted: Thu May 28, 2009 6:34 pm
Everything you need to know start to finish is on my AC DVD. From installing, using which parts, pulling a vacuum, charging, electrical schematic lecture, etc, etc.
Specifically covers C/S/M's that swapped a 4G63 in and want A/C
http://lilevo.com/html/body_acdvd.html
PostPosted: Fri May 29, 2009 7:14 am
You only think you want AC. I know you really don't though. lol
PostPosted: Fri May 29, 2009 9:24 am
I don't regret it at all :) It was awesome last year to the shootout and back.
46 degree arctic wind when it's 90 degrees and humid out. I was going for the OEM look.
PostPosted: Wed Jun 03, 2009 11:46 pm
Does the 1.5 compressor work on the 4g6x?
PostPosted: Thu Jun 04, 2009 3:11 pm
I think the pulleys are different but I'm not sure.
PostPosted: Thu Jun 04, 2009 4:12 pm
Well I just picked up the 1.5 stuff. We'll see how it goes. I also have a 4g63 compressor out of a 91 awd.
PostPosted: Thu Jun 04, 2009 6:00 pm
Neither will work
PostPosted: Tue Jun 09, 2009 7:50 pm
I think u need the elantra that has the 4g motor in it. out of the 92 and up . I belive
Tyler,
PostPosted: Wed Jul 15, 2009 6:10 pm
The 1.5 compressor did not mate to the 4g63 ac mount bracket and it went back to the wrecker.
I also notice my condenser has a hole :-? . If I get my car on the road this summer I may try to get this working.
PostPosted: Sat Jul 18, 2009 3:09 pm
I know the 1.5 does not work I am pretty sure u need the 4g61 elentra ac compresser but thats just here say I could be wrong.
PostPosted: Sat Jul 18, 2009 6:52 pm
I have a 1.6 compressor and mount. PM me if you're interested.
