Wow, been a while since I updated this.
Ok here goes...
After my last update a few posts up, cambelt had jumped a couple of teeth, decided to pull the car off the road for a month or so to fix it up. However, while it was off the road, rather than fixing, I decided to do some upgrading. Not surprisingly, it ended up being off the road for 8 months
a handful of decent mods done in the meantime -
AFCO Scirocco radiator
New turbo. b16G core, Grand National wheel, MSE TD06 compressor cover, Evo 7cm exhaust side
Points right at the engine mount, how convenient
Locator pin had been removed luckily so it was a breeze to rotate
Some other bits
Whack it all together, tadaa!
Wasn't happy with how the turbo was performing. The car hauled arse, but had pretty bad problems with surge during low rpm/high load conditions. Sooo, the car ended up off the road again while I pulled the turbo off.
But, same old dsm'er type attitude, ended up going a bit overboard with the upgrades...
New 4" anti-surge compressor cover, should hopefully eliminate the problem
New oil cooler fittings for braided lines
Exhaust manifold and o2 housing coated in HPC HiPerCoat Extreme (thermal barrier coating)
Candy red powdercoated valve cover
And bought a whole bunch of new gaskets/nuts/bolts/banjos/washers etc etc from my local dealership, thought I might as well replace the whole lot so I don't have to have this turbo off again for some stupid reason anytime in the new future.
Couple of pics of it as it sits. Hoping to have it running sometime this week or next. Can't wait!
Turbo setup all reinstalled. New valve cover just sitting on the old one, have not fitted it yet
