Hey all. Name's Tony. I've been on the board for a month or so, and let me just say that this board is awesome. I've always been a CSM fanatic, and I'm trying to get a CSM project of my own going. Until then I have to live vicariously through friend's cars and such, but I've been into DSM's for 7 years or so, and thought I'd share some pics and info of my baby.
The car is a 1991 Eclipse GSX. I bought it in August '03 for $1,500. It had 151,000 miles on the clock and needed some serious TLC. The motor had bad compression, but I still managed to drive it for 30,000 miles before it finally gave in on me. Anyway, here's the mod-list:
Engine Mods
Built 2.0 4G63
8.5:1 JE pistons
Eagle Rods
Removed Balance Shafts
ARP hardware
Mitsu 4-layer metal head gasket
Prothane Urethane Motor Mount Inserts
5-angle valve job
HKS 272/272 Cams
Otherwise totally stock head
Turbo/Exhaust/Intake
PTE SCM6132E (56-trim compressor, 76-trim Stage 5 T3 turbine wheel)
Ported 2g Manifold
TiAL 35mm external wastegate
HRC 3" SS 02 Eliminator Downpipe
SS 3" Test-Pipe
ATR SS 3" Cat-Back
NSFab 3" Aluminum Intake Pipe
Spearco 2-216 "Race Core" FMIC
NSFab 2.5" Aluminum Intercooler Piping
Greddy Type-S BOV
Fuel & Management
Siemen/Deka 890cc Injectors
Walbro 255HP Fuel Pump (re-wired)
Aeromotive Adj. FPR (43psi base)
ECU+ Piggyback Engine Management System
3" GM MAF (blow-thru)
Zeitronix ZT-2 Wideband A/F Ratio Meter w/ Boost and EGT gauges
NSFab EPROM ECU Modifications
Suspension/Drivetrain/Brakes
KYB ABX Struts
Eibach Pro-Kit Springs
Suspension Techniques 1" Rear Sway Bar
Energy Suspension Urethane Bushings
ACT 2900lb Clutch Kit
Fidanza Aluminum Flywheel
Forced Performance Flywheel Hardware Kit
4-Bolt LSD Rear End
'94 Dual Piston AWD Calipers
CHP Slotted "big" Brake Rotors (front only)
Axxis Ultimate Ceramic Pads (front only)
Interior/Exterior/Misc Mods
Symborski Metal Bushing Shifter Kit
OEM Heavy Leather Shift Knob
Defi Oil Pressure Gauge
No-Name Carbon-Fiber Hood
Carbontrix 18x10" Carbon-Fiber Vent
RRE Custom Headlight Vent
'94 Eclipse German Taillights
16x7.5" Kosei K1 Rims (Gunmetal)
225/50ZR16" Dunlop SP8000
There are probably a few things I'm forgetting, but I'm sure you guys get the jist of it. Here are some of the most recent pics I've taken of the car:
My best time in the 1/4-mile was 12.2 @ 116mph. This was done on the stock motor and a TD05 20g. 720cc Injectors, 2g MAF, and a small 18x6" Griffin Top-to-Bottom FMIC. The motor was blown, had 60% leakdown in the #2 cylinder and not much better compression in any of the other cylinders. This was done on C-16 fuel and crappy tuning with boost spiking to 26psi and falling off to 24psi by redline. I haven't ran the car 1/4-mile yet with this setup, but I'm hoping for some pretty good times.
As far as future mods are concerned, I'm DYING for a Built Tranny, AEM EMS, Larger Injectors, Sheet-Metal Intake Manifold, 75mm Throttle Body, 3" Upper IC pipe, TiAL BOV, Tubular Exhaust Manifold, and a TiAL 44mm External Wastegate.
Thanks for the space guys, I hope you like.
~Tony
