Good day all!
1st off, big thank you to Paul Mezz for workin' on the problems I had logging in. 2ndly to socrateez for his assistance in contacting Paul of my dilemma. It's great to be in! Much fun to be had I'm sure.
My name's Russ. I work at a golf club.
I don't drive a 3rd gen Rage, but I do have a modded 4th gen. 1994 Eagle Summit, 2dr coupe, 5spd, no frills or options.{not even a cupholder man!}
4g15 engine ;
: RPW streetstyle header, 2.25" exhaust, Pro Flo resonator, Magnaflow muffler, no cat.
: 3"polished alum tube short ram intake w/K&N filter{45o bend universal tube, custom brackets. Ends up directly behind the battery.}
: NGK iridium plugs and NGK wires.
: 160o thermostat{supposedly fools the ecm into thinking it needs to run at warm up mode so it makes it run a bit richer. Seems to work.}
I have yet to port match my intake opening and install a custom bored 50mm 4g15 TB and have yet to arrive from RPW;
their Rising rate Fuel Pressure Regulator w/gauge and their Short Shifter. Also a set of 210c injectors from a 1.8 to arrive from a private seller.
Suspension and handling;
: Intrax progressive rate lowering springs, 1.5" fr, 1.7" rr.
: new Monroe Sensitrac shocks and struts
: Pilot fr. strut brace
Other stuff;
: 15" Racing Sparco Nitro II's w/195-50 Ventus H101's{winter driving}
: 17" RS limited Concept Pro's w/205-40 Fulda Extremo ZR's{summer}
: RCI Poly race buckets
: Some bling on the engine and in the interior, tinted rear side and rear windows and,
: I.C.E. Premier head unit, 4 Rev series speakers, 10" Premier subwoofer and Pioneer 300 watt amp.
Future plans;
I'm in the process of acquiring a used bodykit from 2 different private sources{pending}, and acquiring, lightweight 16" wheels{Enkei RPF-1's or Racing Hart CP-35's}with new 205 or 215-40's, perhaps an RPW stage 1 cam, some head work, phenolic intake spacer, some kinda' ignition upgrades, and bodywork and paint.
And am mulling over the idea of Nitrious, but it'll be strictly a streetcar. It's my daily driver, you see, So No2 probably doesn't make any practical sense.
Sorry all. No pics. Well, none that I can post or attach. This summer for sure.
Thanks for having me gang!
G.
