It is currently Sat Apr 27, 2024 3:25 pm
PostPosted: Thu Nov 04, 2004 6:46 am
Originally 91' Mitsubishi Mirage AT 3 speed hatchback
Swapped 4g15 to 1992 4g63t Eclipse Gst 5-speed
-1g dsm shift links used
-same model gearings and hydralic clutch lines, master cylinder
-1g dsm slave cylinder
- shortbock built by jackson auto machine
- cometic metal head gasket
-arp main studs and exhaust studs
- 3 angle valve job
-port and polished heads and intake manifold
-intake heat spacer
-jackson auto titanium retainers
-evo 8 sodium filled exhaust valves and venolia intake valves
-bonze valve guides by jackson auto
-copper exhaust seal
-tubular ss 7cm2 exhaust manifold
-precision scm50 garrett hybrid turbo rated@450hp
-machv 1g dsm intake pipe with blitz sus filter
-jackson auto manual boost controller
-ported evo o2 turbo outlet pipe
-custom 3'' pipings from downpipe to apexi exhaust
-550 rc engineering injectors
-255 walbro fuel pump
-apexi safc2
-custom big sidemount intercooler by dejontool
-stock 1g dsm crushed bov
-3'' gm maf with translater
-2.5''custom pipe from dejontool for use of gm to vent to atmosphere
-racetep water/alcohal injection kit
-stage 3 6 pluck clutch kit by aika clutches
-phantom grip lsd
-bearing shift kit
External Upgrades
-front and rear body kit custom from 97 integra erebuni's shogun kit
-blitz side skirt from 92 civic
-shaved antenna
-custom grill with floating emblem from 92 c50 sedan
-evo 5 hood custom from fiberglass by me
-side deflectors to have traction at higher speeds
-jdm side markers
-16" primax rims with 50 series bf goodrich drag radials
-drag studs by moroso custom fitted from gm vehicals
-spacers from 89' hyndai precis to fit custom wheels
-gr2 front&rear struts with stock 92 'eclipse springs with bump stoppers
-1g vracing front strut bar
-1g megan rear strut bar with custom bolt to fit(if need help email me)
-hella big spot lights in front
-gauge pods custom into existing side interior
-autometer phantom air/fuel ratio, voltmeter,boost gauge, tachometer
Plans to:
-aem ems or halteck ecu upgrade
-apexi bov
-apexi boost controller
-custom jic coilover for 1g dsm
-intercooler chiller kit
-scm61 garrett hybrid turbo
-external wastegate
-paint the car silver
-put decals on the car of my favorite sites and manufactures that powered my car :D maybe one of yours heh.
-bogart drag wheels with slicks
-aluminum radiator
PostPosted: Thu Nov 04, 2004 10:04 pm
Not any more! :)
Noice!
Users browsing this forum: No registered users and 65 guests
