It is currently Sat Apr 27, 2024 3:47 am
 Post subject: 1/4 mile times
PostPosted: Mon Feb 16, 2004 3:56 am
wats the 1/4 mile time or the 0-100km time for a colt/lacer (wat ever u wat to call it) with the 4g61 non turbo i think it does 18sec 2 1/4 mile any one know the real time, it has 90kw so i though it would do 16sec but no way for my car
LAnCeR GsR 4G61
69.7KW @ 6000rpm
Genie Header
2.25" Exhaust with 4'' 3A muffler
K&N Airfilter
60mm throttle body
PostPosted: Mon Feb 16, 2004 8:57 am
You car is not as fast as you expected due to two factors: The first one is the ape you carry around on it. It's unneccessary weigth. Also its constant jumping and jerking will make your car loose traction. :wink:
I think a time between high 16s and low 17s is normal for a stock 4G61 NA powered CSM.
Got rabies?
PostPosted: Thu Feb 19, 2004 5:33 am
my best with a colt gti (4g61 n/a)was 16.8 with a slipping clutch.
PostPosted: Fri Feb 20, 2004 6:35 am
GTi??!? :o Hey beancolt where are you from?
BTW, please enter a valid location in your profile. It is considered as important here, especially when dealing in the Forsale/wanted section.
Got rabies?
PostPosted: Thu Feb 26, 2004 5:24 am
im from scotland.
PostPosted: Thu Feb 26, 2004 6:21 am
im from Australia it saids so, i dont think its 16sec 1/4 mile maby turbo colt not n/a
LAnCeR GsR 4G61
69.7KW @ 6000rpm
Genie Header
K&N Airfilter
60mm throttle body
PostPosted: Thu Feb 26, 2004 10:01 am
I have a colt GTi and although I don't know the 1/4 mile my 1/8 mile was 10s flat. I don't know what the 1/4 mile would be though.
PostPosted: Thu Feb 26, 2004 10:21 am
well i have the slip that tells me thats the time.my speed was 82mph,this is with two people in the car and a set of 215/45/17's so im sure it would be quicker with the standard 14's.
PostPosted: Tue Mar 02, 2004 1:23 am
i do 0 - 100km in low 10s, we got bord :lol: and we tested all our cars
LAnCeR GsR 4G61
69.7KW @ 6000rpm
Genie Header
K&N Airfilter
60mm throttle body
