It is currently Sat Apr 27, 2024 10:04 pm
PostPosted: Wed Feb 18, 2015 11:58 am
The plastic fender trim door guard piece for the drivers side, whatever it's called.
The spacer that goes behind the window crank to fill the gap between the door panel need 2, if that exists...
Thanks!
PostPosted: Wed Feb 18, 2015 9:26 pm
If you don't find an actual Colt/Mirage piece for your window crank, many cars shared this type of part.
At the local Canadian Tires, there was a little part section with boxes labelled "HELP".
They contained pieces like window cranks and also the trim piece that goes behind them.
I would suspect that any late 80'searly 90's era window crank from a Mitsu or even maybe Hyundai would work.
IIRC, those spacers were black on our cars, regardless of door car trim?
I looked it up in ASA, this showed up:
67203 MB726650 Escutcheon front door window regulator handle quantity 2 black
Follow the cookie trail:
http://www.partsbase.org/parts/mitsubishi-mb726650/
amayama.com
http://www.amayama.com/search?region=315&q=mb726650
Japan, if it's stocked. 8)
PostPosted: Thu Feb 19, 2015 1:47 pm
Thanks Eagle.
PostPosted: Thu Feb 19, 2015 5:53 pm
Are you talking about the actual molding that snaps onto the fender? If so will black work or do you need a certain color? I can probably grab the window crank trim pieces off of something for you too. Like Tim said, all cars from that era were similar. But there is a 3g sedan that came in not too long ago, I'm betting those parts are still there.
PostPosted: Thu Feb 19, 2015 6:05 pm
Yes the snap-in trim, any color. Thanks.
PostPosted: Sat Mar 21, 2015 11:11 am
Still looking.
