It is currently Sat Apr 27, 2024 2:57 pm
 Post subject: Good F5M21 trans
PostPosted: Thu Dec 04, 2014 9:43 pm
Im in need of a good F5M21 trans. Must be good shifting and not need a rebuild. I live in Northwest Indiana ,30 minutes from Chicago. Contact me 219-308-2790 my name is Rob.
 Post subject: Re: Good F5M21 trans
PostPosted: Fri Dec 05, 2014 12:10 pm
Or a f5m31 trans as I have been told will work.
PostPosted: Fri Dec 05, 2014 2:40 pm
F5m31 will require another trans mount to work properly.
Stepped mounting bracket.
Edit ==== The F5M31 is the KM210, which needs a turbo colt mount or other (not sure what else had this and was compatible).
Yes, 89Mirageman is correct as this puts you into the territory for a larger flywheel and clutch setup.
Good news is, most people swap out stock type of stuff and sometimes before punishing the car because they know a torquey turbo setup won't be compatible
any longer.
Good price point when that comes about, stock flywheel and clutch.
Also, the starter is different between the F5M21 *4g15 motors* and the 4g6X motors.
So, best to find a decent F5M21 trans IMHO.
PostPosted: Fri Dec 05, 2014 3:54 pm
Doesn't the F5M31 have the larger bell housing for a stepped flywheel too?
PostPosted: Fri Dec 05, 2014 5:15 pm
I can deal with the mount. Just want to make sure I can use my clutch,flywheel and axles.
PostPosted: Sat Dec 06, 2014 8:47 am
So does anybody have a good F5M21 trans? This shouldn't be so hard to find.
PostPosted: Sat Dec 06, 2014 8:58 am
I just looked up starter for my 92 mirage and a 92 eclipse and they are the same part number.
PostPosted: Sat Dec 06, 2014 9:18 am
Have a read through here, food for thought. Starter may work, you would be the first to post that I can remember, unless something was posted years ago. Site goes back to 2003, might or might not be listed here.
Click for Archived Starter thread
PostPosted: Mon Dec 22, 2014 12:09 pm
Be sure the axle spline lengths that go int the trans are the same.
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
