It is currently Sun Apr 28, 2024 6:45 am
PostPosted: Wed May 02, 2018 10:28 pm
have a handful of parts left over and some other stuff, all prices include shipping in the USA.
DNP t4 divided exhaust manifold, coated, with dump tube. Great shape $450
holset hx35. T3, 12cm turbine housing, from 97ish Cummins, the inlet hose clamp area has been slightly broken out, looks like someone pried on it to remove silencer ring, still perfectly functional. I can fix if desired. Comp wheel in great shape, turbo is tight. $350
750cc injectors, working great when pulled. $150
2g Maf, 609 with filter adapter. $40
Dsmchips eprom chip. 750cc injectors, 2g Maf, phantom knock, 8500 rpm limiter, 6k launch control (selectable 2 step) $10
Evo 8 fuel pump $20
The above setup (chip, pump, Maf, and injectorsj with an afc and a evo 16g made 360whp and 380trq in my colt on the dunk. With a sleeper 16g, (20g) made 405hp and 395trq. I’ll make a package deal for someone.
Fp cast intake pipe. with recirc hose bung, really good shape $65
Beefy side mount inter cooler, cast end tanks, bar and plate core, 10x10x3.5, might not fit a csm, but Dsm for sure. $100
2g DSM shift base with short shifter handle $40. Handle may fit 1g and csm.
Maf translator setup. With gm Maf. I am not sure what injectors it’s set for, probably the 750cc injectors above. Was working when removed to install Ecmlink. $50
Unorthodox racing underdrive crank pulley, red, for 7bolt, not sure if it will fit a 6bolt. On 0209106
Decent shape. $40
Specter 3” air filter. $13
1g DSM armrest cupholder, great shape, $15
6bolt fwd 3SPEED Stainless scatter shield. Does not include hardware, might not fit colt get shifter cables, will fit Dsm cables with factory spacer plate. $150
Original colt gt turbo setup, 11b turbo, all boost piping, intake piping, manifold and wg actuator, as well as bov. Anything you would need to turbo a 1.6 or 1.8 4g6x. $100
All prices include shipping, are obo, as long as you don’t lowball, all fair offers will be taken into consideration.
I just opened a new Flickr account, not sure how to post just yet, but can send pics on request.
9403952106
Thanks,
Graham
PostPosted: Sat May 19, 2018 7:07 pm
Updated
