It is currently Fri Jun 07, 2024 2:01 am
 Post subject: 3G CSM A/C setup wiring.
PostPosted: Sat Sep 02, 2017 8:45 pm
I have a cool deal on an A/C wiring loom with relays/fuse box, it came from an a/c equipped 3G CSM, this is a good setup for guys that never had A/C on their 3G CSM from the factory, this is all the wiring you need for the under-hood section, not sure if you need under dash stuff as well... pretty sure there are a few things down there that are needed , I did pull the on off switch from the interior so that will be included.
I also have a good a/c compressor with clutch, however the pulley and bracket is missing, but I might be able to source a dohc or sohc version and add it to the sale for an added fee.
I'm asking $100 for all of it plus shipping charges.
I am willing to separate parts listed
for the wiring and switch $50 plus whatever shipping is.
for the compressor $50 plus whatever shipping is.
Abe
PostPosted: Sat Sep 02, 2017 8:59 pm
image of econo on or off switch.
Abe
PostPosted: Thu Sep 07, 2017 10:22 pm
FYI, anybody looking to put this on their swapped csm you can use the bracket and tensioner off any 89-93 Galant. They are a bit easier to find than DOHC 3g stuff.
PostPosted: Fri Sep 08, 2017 1:43 am
I probably will end up just getting the pulley and mounting bracket from an 89-93 galant, that way the buyer will be getting the whole deal and no more hunting, next time I see an 89-93 galant I'm snatching these up.
also I just remembered the cooling unit and a/c controller that goes under the dash is a must for the swap so I might head out and get that stuff too the car I pulled the stuff from has super low miles about 71,000 miles on it.
Abe
PostPosted: Wed Dec 27, 2017 12:44 am
Update: I now have the proper pulley and tensioner if you want to use this setup in a 4G63T swapped or DOHC 1.6 mirage and keep A/C.
Pictures will be up shortly.
$45 plus shipping and paypal for the pulleys and tensioner bracket alone+shipping/paypal fees.
Abe
