FS: 1990 Plymouth Colt GL 4g63t Roller 85k miles - $2500 http://4g61t.org/forum/viewtopic.php?f=66&t=40448 |
Author: | ctwombly [ Fri Nov 27, 2015 2:42 pm ] |
Post subject: | FS: 1990 Plymouth Colt GL 4g63t Roller 85k miles - $2500 |
1990 Plymouth Colt GL Mileage: 85,113 mi VIN: JP3CU24X3LU005551 Price: $2500/obo Original cable clutch converted to hydro clutch Clean VIN and straight body that is in excellent condition Colt GT seats ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Many more pictures are available at the following link to my Photobucket library: http://s392.photobucket.com/user/TwomzG ... 0Colt%20GL Engine Stock 6 bolt 4g63t pulled out of a perfectly running 92 TSi that had been overhauled in the past (103k miles) Timing belt and all timing components (OEM) plus water pump (Top Line) have ~3k miles of use Clean cylinder head that was rebuilt in the past, but not sure exact mileage HKS 264 intake cam and HKS 272 exhaust cam Turbo (all parts with ~3k miles of use) FP Race exhaust manifold Genuine Mitsu EVO3 16g Genuine Mitsu EVO3 O2 housing Exhaust Custom stainless steel 3" turbo back with Magnaflow muffler (exits just before LR wheel) No catalytic converter Intake/Intercooler Aluminum intake pipe for 2G MAF 2G MAF Stock 4g63 SMIC (also have an Extreme upgraded SMIC that I could sell packaged with the car) Stock compressor outlet pipe 1.75" silicone straight hose (~10 feet to make custom IC piping) Stock BOV hard pipe with 1g BOV from 4g63t 2G TB elbow Freshly rebuilt 1g turbo TB from Steve @ throttlebodys.com (new everything with FIAV blockoff) Stock 1g turbo intake manifold Fuel FIC 720cc injectors (I'm 90% sure on that and will need to verify, else they are FIC 680cc) -6AN Russel fuel filter with stock fuel line to -6AN adapter (bought from LILEVO on ebay) -6AN feed line stock 4g63 fuel rail -6AN fuel rail outlet Aeromotive adjustable FPR New rubber return line with custom reducer Rewired fuel pump Brand new Walbro 255HP fuel pump Drivetrain Freshly resurfaced Fidanza aluminum flywheel ACT 2600 with street disc 1g turbo FWD F5M33 5 speed manual transmission Colt GT axles (new boot and grease on one of the axles) New clutch master cylinder New slave cylinder (not installed) New stainless steel braided line from master to slave New OEM Mitsu throwout bearing Suspension/Steering Manual steering rack Brand new KYB GR2 struts all around 1g DSM lowering springs up front 1g DSM AWD stock rear springs in rear Brand new brembo rotors, rebuilt calipers, disc pads, and brake lines up front Brakes were upgraded to Colt GT brakes (bigger, vented rotors and bigger calipers/pads) Brand new inner/outer tie rods Brand new ball joint on passenger side (driver side is in good shape) Upgraded Colt GT front sway bar with brand new OEM sway bar bushings Wheels Stock 14" steelies Very good condition, used Michelin X-Radial All Season Tires (195/70R14) Just had the tires installed and balanced a couple months ago Electrical/Wiring 91+ 4g63t engine harness (has been de-loomed for a cleaner install) 4g63t engine to Colt interior plug and play adapter harness Battery relocation to trunk Custom aluminum battery hold down Odyssey small battery mounted in spare tire area of trunk Fuel pump rewired and Bosch relay accessible in spare tire area with fail-safe connection (jumper wires added in case relay fails and you need to get the car started again) Missing Parts ECU (I have several 4g63t ECUs and couple with DSMLink but they'll be sold separately) Coupler to attach 2g intake pipe to turbo Coupler to attach 2.5" 2g TB elbow to 1.75" 1g BOV hard pipe Boost controller (I have a few MBCs and can throw one in) Radiator and hoses Items Left to Complete
If you'd prefer to go a different route such as GM MAFT or speed density with a FMIC and DSMLink to tune it all, I can drop the 2g MAF and intake pipe along with the SMIC and silicone piping and offer the car for $100 less. I was going for a simple setup to get this finished quicker, but a FMIC and at least GM MAFT with DSMLink would be the way to go. I do have a few FMIC kits, lots of IC piping, Tial BOVs, and GM MAFTs among tons of other parts so if you're thinking about a different setup, I do have those parts for sale separately. I will be posting up all of my remaining parts in the coming days. Feel free to PM me with any additional questions you may have. Thanks for the space! |
Author: | ctwombly [ Thu Dec 24, 2015 2:24 pm ] |
Post subject: | Re: FS: 1990 Plymouth Colt GL 4g63t Roller 85k miles - $2500 |
Bump |
Author: | Briggs2056 [ Fri Dec 25, 2015 3:48 am ] |
Firm @2500? |
Author: | coltdriver92 [ Sat Dec 26, 2015 12:56 am ] |
I want this, but I'm leaving to go on deployment in a month:/ Can I have your front seats? All kidding aside, glws. |
Author: | darkside13 [ Wed Jan 06, 2016 1:05 pm ] |
PM sent. |
