It is currently Sun Oct 26, 2025 12:51 am
PostPosted: Mon Aug 25, 2014 10:06 pm
I'm thinking of letting go of my Mirage. First off there is an engine noise that has developed. I'm happy to go into details for those interested but I have a feeling it may be a rod bearing starting to go. It can only be heard at specific rpms while driving. Car runs and drives perfect. Could be relatively simple but i'm considering getting out of things all together and cutting my losses. Just noticed the noise this weekend and have not driven it since looking into the noise. I have not pulled the pan yet to inspect.
With that in mind here's the good stuff:
92 Mitsubishi Mirage GS sedan. Rumored to be less than 500 produced making it rarer than the factory 89 turbo Colts & Mirages. Originally came with an n/t 4G61 1.6 DOHC, four wheel disc brakes, black and red gt trim, 92 only clear signal taillights, bolstered turbo seats with unique upholstery, 7000rpm tach cluster.
The paint is in very good condition for the age, couple scratches, one small dent under the taillight, left rear rocker is rusting but not noticeable unless you look underneath
Chassis:
-188k miles
-Heat and AC system removed, no power steering, no wipers, no stereo, no carpet or sound deadening, front and rear crash bars removed, trunk gutted. Still retains factory dash, door panels, and seats. Car weighs 2255 lbs
-Autometer 45psi boost gauge, digital coolant temp gauge
-KYB GR2 struts, newer rears, cut 1G awd rear springs
-Galant GSX wheels with 8mm spacers and worn 225/50/15 BFG Drag radials up front, 195/50/15 Hankook ventus tires at the rear
-Both front and left rear brake calipers have been replaced with new reman units
Engine:
-Rebuilt 6-bolt turbo bottom end with supposedly under 30k miles. 2g pistons with 1g rods and balance shaft delete. Stock bolts. 6-bolt head rebuilt by Force Engineering 2k miles ago with 3 angle valve job, Manley single springs, and stainless studs
-ARP headstuds
-HKS 264/272 cams with AEM cam gears
-10AN crankcase vents to vented catch can
-Forward facing oil filter housing
-Oil pan modified with 12AN fitting
Electronics/fuel system:
-Running Megasquirt-II standalone ecu speed density. Custom engine wiring harness and 4 bar map sensor. GM temp sensors.
-FIC Bluemax 1650cc injectors 1k miles
-Walbro 450lph E85 fuel pump
-Innovate LC1 wideband o2 sensor
-Stock coils with NGK wires and BR7ES plugs
Turbo/exhaust setup
-Custom T3 manifold with 38mm turbonetics wastegate
-Holset HX35W 7-blade turbo with 1k miles since brand new with Tims Turbos .63 exhaust housing and 4-bolt 2.5" o2 housing. 4AN feed with restrictor and 12AN drain
-3" turboback straight piped with turn down under vehicle before fuel tank
Cooling system:
-Custom CSM specific ETS street fmic, 2.5" piping, knockoff tial 50mm bov, N/T 2.0 throttlebody with fiav/iac blockoff and new shaft seals
-AFCO aluminum dual core scirocco radiator with Deraile cooling fan
Driveline:
-90 eclipse gst transmission with FF Dynamics LSD insert and taller 5th gear. Supposedly rebuilt but unknown miles
-ACT lightweight flywheel, ACT 2100 pressure plate, ACT 6-puck unsprung disc
-Custom solid front motor mount
-Slicks also available. Drag dr27 15x7 et0 14.5lbs with 24.5x8x15 M/T ET Drags
The car made 445whp/420wtq at 29-30psi on Force Engineering's mustang dyno. Safe tune with only 12 degrees timing. Didn't push it much more being that it has stock rod bolts. The car traps 125MPH, easily a mid 11 second car on slicks. Only tried the slicks a couple times and never made a clean pass. Will spin the tires clear through third on drag radials on the street.
All things considered i'd be asking $2,000 OBO in its current condition. I know I could part it out for more but I really don't want to do that for a numer of reasons. If interested please e-mail me at tsbeaz@gmail.com. I have had virtually every single nut and bolt apart on this car and can answer any question you would have. I'm probably forgetting some little things but most of the important stuff is listed.
PostPosted: Tue Aug 26, 2014 6:20 am
Here is my kind of up to date build thread. viewtopic.php?f=64&t=36316
PostPosted: Mon Sep 08, 2014 7:10 pm
UPDATE:
Oil pan was removed to look for engine noise. Rod bearings were not spun but were questionable. All new were replaced with acl race bearings. Something went wrong torque wise or something. Engine was running fine no noise and then stalled on test drive. Bottom end seems seized, does not turn over. Less than 20 miles on new bearings. I am confident the top end is fine but would plan for a bottom end rebuild or shortblock in order to be running. I've had my fun for the last three years and now it's somebody else's turn. I have well over 5K into the car. The car is still complete at this time. I would like to try and sell it off as whole before tearing it down to part out. I have the old bearings and can answer any questions. ASKING $2,000 OBO FOR EVERYTHING AND I STRESS THE O-B-O! Humor me!
PostPosted: Wed Sep 10, 2014 2:41 am
Interested...I emailed ya!
Thanks!
Adrian
PostPosted: Wed Sep 10, 2014 8:04 am
Pending sale
PostPosted: Wed Sep 10, 2014 8:13 am
Darn that was quick:(
Adrian
PostPosted: Sat Sep 13, 2014 11:44 am
Might as well consider this sold.
PostPosted: Sat Nov 15, 2014 11:57 pm
Is this sold?
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
