It is currently Sat Nov 01, 2025 8:14 pm
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Fri Nov 05, 2010 11:03 am
Sold sold sold
Price drop to 3750 will consider trades on 400+cc dirtbike
Well the time has finally come for me to sell my Colt after many months of debate and many years of great memories. The car originally started life as a Non turbo FWD car that had a lot of miles on it like 200k+ and I drove it for about 50 miles that way then the engine was pulled and in its place went the 4g63 out of a 91 or so talon and an AWD 5 speed trans. The trans broke and so I took it out and in its place went a FWD auto trans which was then replaced by an AWD automatic trans when the AWD conversion was done. The Conversion was done about 4k miles ago maybe a few less but has many many drag passes without a single break. I have not really put a lot of miles on the car as it is mostly a drag car. The conversion was done professionally at a good friends shop and the work was completed by either myself, my friend or his father. The stock driveshaft for the car was professionally shortened by frontrange driveline and the u-joints replaced at that time. The car currently has a three bolt rear end and I have an automatic 4 bolt that has not been put in but will come with the sale of the car. the automatic trans was rebuilt before being installed and had additional clutch packs installed using all oem rebuild parts and new solenoids replaced the car was also fitted with a used IPT restalled converter and works perfectly. The trans should be pulled apart and looked at by a professional to make sure all things are still in good shape and the fluid changed as I raced all last season on the fluid and went out just once this summer. The mods currently on the vehicle are as follows.
Engine:
V3 ecmlink
1g to gm-maf ecmlink cable and 3'gm maf
stock block (BS removed) and head with HKS 264 in/ex cams
PTE 50 trim turbo with proper restrictor and -4 feed line from Oil filter housing
FP 4" intake
custom battery install and wiring harness for the car
top to bottom intercooler (spearco style 2.5"in/out)
2.5" intercooler piping
HKS SSQV BOV with recirc fitting
NX wet nitrous oxide system
thicker than stock radiator
165 degree thermostat
trans cooler made for 24.5k GVW
Trans temp, oil pressure (sensor broken), and boost gauge
version 1 SBR exh. manifold and evo 3 O2 housing
exterior:
mirage turbo FWD axles and AWD dsm spindles in the front so you have bigger DSM brakes and the conversion took the rear brakes from the talon.
colt filler panel and original turbo wing
Drag DR-17, flat black, 15" rims with falken ZE512 tires with plenty of tread left
hood pins
interior:
well everything is removed and the most of the cage is finished just two door bars to complete it.
ipt electromatic controller (push button shifter)
1 g dsm shifter
kirkey race seat mounted on the stock slider but not able to moved due to rear brace.
g force 5 point seat belt with cam lock
1g talon steering wheel
custom gas tank cover
I also have new KYB Gr-2 shocks that I will include with the sale and nyother parts I have for DSM’s as I am done with them.
things the car needs.
alignment (the DSM spindles mess up the front end camber pretty bad and it needs to be aligned again the current struts are slotted to help)
tune (it just needs a new tune as it has been a while)
suspension-the stock shocks are toasted.
paint is terrible and there are a few dings on the car here are a couple pics and the rest are in my photobucket album.
Last time out the car ran a few solid 11.8 runs with a 75 wet shot, before it ran 11.6 and 11.7 on a 50 shot (thus I think the need for a retune)
photobucket album
http://s209.photobucket.com/albums/bb28 ... sale%205k/
I am looking for 5k for the car and am open to offers, but will not be low balled as i dont have to sell the car but for a 11 second car you are getting a good deal.
Thanks,
Paul
Last edited by 240addiction on Tue Jan 05, 2016 12:27 am, edited 2 times in total.
PostPosted: Fri Nov 05, 2010 11:24 am
I contemplated the auto/awd swap but figured the engine bay was too cramped as it is. How the hell do you get the in/out?
Good luck with the sale, would make for a great track car.
PostPosted: Fri Nov 05, 2010 11:30 am
Honestly.......
It fruit and banana sucks because an auto weighs easily 2x a manual trans and you have to bench press it in while keeping the converter from falling out and not dropping the trans in your chest . Not fun
PostPosted: Fri Nov 05, 2010 12:45 pm
I am sad to see it go Paul. I can vouch the for the seller and the work done on the car. This is a very solid 11 second car for sure and is a great sleeper!
AWD What?
PostPosted: Fri Nov 05, 2010 1:49 pm
sounds like your 75shot was just to rich :weedman:
and would you be interested in a 2004 Suzuki gsxr 1000 very mint and with only 12k miles??? :rolleyes:
PostPosted: Fri Nov 05, 2010 2:06 pm
Wanna trade for one of the cleanest DSM's you've ever seen? Haha
PostPosted: Fri Nov 05, 2010 3:50 pm
maybe some details?
PostPosted: Fri Nov 05, 2010 5:20 pm
call me lets wok something out i will pay your price....
Str8fuct......
PostPosted: Tue Nov 09, 2010 8:48 am
TTT
PostPosted: Wed Nov 17, 2010 3:11 pm
Ttt
PostPosted: Fri Jan 07, 2011 9:51 am
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 302wt_1165
EBAY time unless I get a good offer otherwise
PostPosted: Sun Feb 06, 2011 10:56 pm
TTT make me an offer!
PostPosted: Mon Feb 07, 2011 1:33 pm
wish you were closer to the east coast. glws
PostPosted: Mon Feb 07, 2011 1:37 pm
Shipping is not that bad just got a quote for 600 to the Ohio area
PostPosted: Mon Feb 07, 2011 1:48 pm
Correction somewhere in Illinois
