It is currently Tue Jun 04, 2024 8:51 am
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
 Post subject: Re: Gauge Faces
PostPosted: Thu Mar 24, 2016 2:00 pm
I can do anything with any colors. I may even be able to use the scans provided for the 89-92 gauge faces.
Keep in mind these could cost upwards of $60-$80 for a set
PostPosted: Fri Mar 25, 2016 2:01 pm
I have a 9k and 145 mph ones. I can send let me know how much one set would be
PostPosted: Sat Mar 26, 2016 8:26 pm
I have the following:
240 KMH Black - Yazaki 750695-091 (with inset yellow 145MPH) CDN market turbo gauge face
9000 RPM TACH Black - Yazaki 750-697-340
It appears the little black tabs that hold the indicator arms, must be removed to get a face down scan. Hopefully they can be reset with little fuss.
PostPosted: Sun Mar 27, 2016 5:29 pm
Unfortunately those are "melted" on the back side to secure them. The gauge faces would come without them.
PostPosted: Sun Mar 27, 2016 7:34 pm
Those little stoppers keep things at the correct starting point so they don't "fall" away at power down.
I think they can be "finagled" off, and glued back in place in the rear retainer ring happens to crack and lose its retenstion capabilities.
I just pulled one off the back of the face, they have a push lock kind feature, whereby they just squeeze over a little hump in the post and voila, locked in.
PostPosted: Wed Mar 30, 2016 4:16 am
Will you do this in KPH?
PostPosted: Wed Mar 30, 2016 12:44 pm
Right now I get the feeling that the KMH is second on the list, because there are literally 5-10 (maybe 20 worldwide) members with KMH gauges/markets that use them.
The rest of our members are in USDM cars with MPH gauges.
PostPosted: Wed Mar 30, 2016 9:53 pm
I will make an update when I have working pics of the white face 9k replicas drafted.
PostPosted: Sun Sep 04, 2016 7:52 am
Hi,
I can send you a the right panel in KPH if you want a "physical" example.
If you can do KPH panel, I will buy a KPH panel and RPM panel and you can send me my "physical example."
Let me know.
PostPosted: Tue Oct 04, 2016 12:06 am
I might be able to send you the USDM 145mph/9k RPM faces. My GT cluster is kind of broken at the point anyway. Would I be able to get the faces back when you are done?
