I have moved to Speed Density and no longer need this setup. It is not beat up garbage (the K&N is a little tweaked).
FP racing 4 inch intake pipe with Diverter Valve nipple. Did not come with a port for valve cover breather, has been drilled and tapped and JB welded, does not leak.
EVO 8 # 399 MAF
Extreme PSI 4 inch to 2.5 inch reducing coupler (allows clocking to fit around wastegates, piping, etc....)
Vibrant Maf adapter
!G to EVO Maf harness adapter pigtail (made by that guy on the VR4 forums)
also comes with silicone coupler from Maf to intake, I think its 3 inch to 4 inch
Also low mile K&N filter (again, it's a little tweaked)
Would prefer to not part out, it's a very big upgrade to a stock 1g or 2g maf and is basically a bolt on kit. DSM LINK V3 has the EVO MAF selectable as a Maf option
$200.00 bucks. Will ship Ground for free in US
EBAY Link with pics:
http://www.ebay.com/itm/401006273294?ss ... 1555.l2649
This stuff has very low miles on it and was only really used for tuning. Probably would cost 350 +++ to piece it together.
$190.00 - Can't let it go for any less!
