Wheatleys AWD http://4g61t.org/forum/viewtopic.php?f=64&t=41139 |
Page 3 of 5 |
Author: | Flying Eagle [ Wed Apr 04, 2018 11:18 am ] |
Post subject: | Re: Wheatleys AWD |
What is the purple after effect on that floor pan outer? Is that a rust converter product? Progress being made, enjoying the updates. |
Author: | Wheatley [ Sun Apr 08, 2018 8:15 am ] |
A cheap 5' led light caused that, luckily its all rust free under there. Rear outside rockers and a spot on the drivers side wheel well under the engine mount are all the rust I've found so far which should be pretty easy to cut out and make some patch panels.
Author: | aaronsbig16g [ Wed Apr 11, 2018 10:36 pm ] |
I need to come over and look at this thing! Making great progress. |
Author: | Wheatley [ Mon Jun 04, 2018 2:23 pm ] |
Come on over and do some work!
Author: | Wheatley [ Thu Oct 18, 2018 9:18 am ] |
25.5 cage is complete. |
Author: | Flying Eagle [ Fri Oct 19, 2018 6:21 pm ] |
Do I see access plates in the rear suspension towers, to allow for wrench access for height changes on the fly without having to remove the struts? |
Author: | 89Mirageman [ Thu Nov 01, 2018 10:32 am ] |
Great job as usual man. I can only imagine how many hours you have spent so far. It's worth it though. |
Author: | Wheatley [ Wed Nov 21, 2018 9:23 am ] |
Nothing cool like that unfortunately, shock towers are 100% stock front and rear. Height and dampening adjustment can all be done easily from below the car.Quote:
Thanks! I'm trying to keep everything stock appearing from the exterior and I'd like the car to appear pretty basic looking. There are some things that I just wont be able to avoid like a hood exit exhaust and one of the wg dumps will likely also have to exit the hood. Its just so tight everywhere. |
Author: | wrx110487 [ Sat Dec 01, 2018 2:22 pm ] |
The cage looks awesome, great job once again. That interior would look perfect in white . Are you going to paint the outside of the car as well? |
Author: | Wheatley [ Mon Dec 10, 2018 9:50 am ] |
Thanks, plan is to paint everything metal on the chassis white and then likely wrap the exterior of the car. I'm hoping this winter to get several of the body panels molded to make some composite items like doors, hatch, hood etc.
Author: | Wheatley [ Sun Jan 20, 2019 7:59 pm ] |
Still waiting on a ton of parts but hoping to start making real progress on the front end this week. Dan is parting the Colt out so I was able to pick up the manifold and finally get the forward facing setup I wanted. The original plan was to go with a Haltech elite 2500 (which is for sale) which is a great ecu imo but is lacking a few things that I wanted in order to try a few ideas out so thanks to a friend of a friend I was able to get into a MoTeC m150. Up to this point everything I have ever ran was either a stock ecu with things like hpt or link and a couple cars with old series 1 aem. I've always had great luck with the others so I hope this m150 can last for a long time. |
Author: | #89 [ Mon Jan 21, 2019 9:49 pm ] |
Post subject: | Woot! Return of the 'Build Threads'! |
"money generating algorithm for viewership is lame af." Thanks for sharing this labor of love with the gang. I especially got a kick out of the Christmas Eve/Santa's Workshop update... impeccable use of the holiday!! Kanpai!, |
Author: | 89Mirageman [ Tue Jan 22, 2019 4:39 pm ] |
That turbo and intercooler setup is insane. When I think back at how scary my little 4g63t swapped colt was with a 16g I can't even imagine how it would be with your setup. Keep the updates coming and great work as usual. |
Author: | Wheatley [ Thu Jan 24, 2019 11:30 am ] |
Page 3 of 5 | All times are UTC-05:00 |
