It is currently Thu May 23, 2024 12:57 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
 Post subject: slowdsm's build
PostPosted: Wed Mar 16, 2011 6:09 pm
well here is the start of it back before they added the build section..
http://www.4g61t.org/forum/viewtopic.php?f=3&t=26327
I havent really done much since then except rewire the whole engine bay harness..deleted alot of the wires...
because yahoo dropped geocities a few years back I lost all my pics from the engine build and stuff.. so figured I would start a new thread since im starting to work on getting the race head and turbo installed in the next few months.. then working on the awd finally... so on to it..
 Post subject: Re: slowdsm's build
PostPosted: Wed Mar 16, 2011 6:22 pm
first off.. BIG props to chris. 89mirageman for alot of my parts to do the front 5 lug brake conversion with elantra LCA's.. 2 piston brake calipers that he rebuild and painted for my.. got my fresh rebuild hubs back today they will get painted this week so they will be ready to go.. just need to get some rotors and pads then the swap begins..
fist off I thought I could be good like chris and paint something nice... HAHAFUCINGHA...not a chance.. he is a god when it comes to cleaning and painting stuff.. here is my attempt..
this is my dumptube...going to also be doing intake..valve cover and all ic piping this color..itws the candy blue.. to many people use the purple so I went blue.. think it will look nice with the white car
Looks good huh... well It was dry to touch so I laid it down to take pics.. BIG mistake lol.
thank god its on the back side so wont be seen..
PostPosted: Wed Mar 16, 2011 6:26 pm
turbo setup and some brake parts.
I will post up some pics of the hubs once I get them painted...along with the intake and VC when there done.
its been a few years since ive done any work/updates.. now im doing 2 at once lol.. this will give us 4 now in our group down here.. so when we roll into a place..we dont have bmw's but we roll in style and fast lol.
PostPosted: Wed Mar 16, 2011 9:20 pm
Looking good so far man! Just sand and feather edge that pipe and repaint it and you'll be good. I always grab a few rolls of wax paper from the dollar store, its the perfect thing to lay parts on that aren't 100% dry.
PostPosted: Thu Mar 17, 2011 1:17 am
Lookin good man, Looks like the warm weather has got you building up a storm!
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Tue Mar 22, 2011 3:19 am
few more pieces to my brakes are completed.. just need rotors and pads then I can swap it all..
and heres the crappy intake paint job. I think I might strip it and have it powder coated instead.
PostPosted: Tue Mar 22, 2011 12:48 pm
That is a good shade of blue.
PostPosted: Tue Mar 22, 2011 11:31 pm
too really get the blue into it you have to let the manifold soak overnite in a bucket of carb cleaner then rinse/wash with hot soapy water and air blow dry, then paint it when done you shoot some clear over it and it looks like its still wet after it dries, but your not a wall tagger dude so we understand, but looks good any way, glad your making progress
PostPosted: Wed Mar 23, 2011 12:45 am
machine shop cleaned it spotless.. I did 2 coats of base color... and 2 coats of the candy blue.. then 3 coats of clear... on both the pipe and the intake.. I am not into making my car fancy just fast.. so this was a trial thing for me lol.. im still not sure I like the intake.. i want it all to look like the wastegate.. but if not ill go all black and race it that way lol. :axe: :finga:
PostPosted: Sat Apr 23, 2011 8:06 pm
so I installed the front dsm big brakes today with thanks to moidsm1 for loaning me the big rotors and some 5 lug rims untill I can afford my own..got the elantra LCAs installed also.. reamed out the top of the dsm knuckle for the tie rod end to sit on top pointing down like the stock colt does.. took all of 2 min per side lol...while in there I noticed both my sway bar bushing that mount it to the fire wall were completely missing.. so I yanked it out.. now to find a elantra one to install.. looks pretty nice sitting in there.. also I took a pic of the front kyb/agx fronts where I put on some cheap 40 ebay coilovers.. it actually rides pretty nice.. rides softer than with the eibach pro springs that was on it.. I was shocked..once I get the exhaust system fixed so I can lower the car ill put the rear setup on to test it out.. and post pics.. for now heres the front end.
and yes when I have the wheel on..and sitting on the ground the spring sits down on the bottom.. next step is to cut the strut so I can lower it more...and make room for some bigger tires.
PostPosted: Sun Apr 24, 2011 7:03 pm
Brakes are looking good!
PostPosted: Mon Apr 25, 2011 9:51 am
Im glad somebody in Tucson is getting some work done! Ive been so busy working on house crap!
88 Cummins Suburban
PostPosted: Wed Dec 14, 2011 11:37 pm
small update.. picked up a awd auto trans and a few other parts for my awd swap..
also just picked up this new treadstone ic..its larger than the 1 I have now.. so it will be a easy direct bolt on.just need new ic piping as its 3" and current is 2 1/2.. it supports up to 1000 hp (supposably)..got it from a local guy here in town.
here is the same one on ebay if anyone else wants one.
http://www.ebay.com/itm/TRV25S-Treadsto ... 67&vxp=mtr
PostPosted: Thu Dec 15, 2011 6:56 am
I would love to have one of these. But not for $410....
PostPosted: Thu Dec 15, 2011 12:37 pm
I traded my brake setup and 100.00 for it.. he was only asking 300 for it and its never been installed.
