1980 4g63t swap -now awd too http://4g61t.org/forum/viewtopic.php?f=64&t=40090 |
Page 3 of 4 |
Author: | Keane [ Sun May 17, 2015 9:55 pm ] |
Post subject: | Re: 1980 4g63t swap |
Man that does look cool. What would be really sweet is to box in where the bumper was with some sheet metal. Like a rollpan for the front. Just fill and flush it out right where the indent in the fender is for the old bumper |
Author: | Flying Eagle [ Sun May 24, 2015 9:50 pm ] |
Get some steelies from an Elantra .. make the move to 14" Yeah!! |
Author: | pimpy rider [ Sun Jul 05, 2015 1:16 pm ] |
limiting straps made it worse, uncontrollable under full throttle, pulled hard to the right and spun worse than before awd swap coming soon gonna strip my awd colt, focus on this one |
Author: | pimpy rider [ Mon Jul 13, 2015 10:51 am ] |
this car is so hilarious at the track!!! 14.7@103.4 spun the whole 1/8 im not going to bother with slicks awd will make this thing legendary, so im starting the swap soon! |
Author: | xxNocturnalxx [ Mon Jul 13, 2015 12:51 pm ] |
Slicks on a properly prepped track will net this thing in the sub 1.8s in the 60'. |
Author: | pimpy rider [ Fri Jul 24, 2015 8:53 pm ] |
i want 1.6 60 on street tires the best i ever did was 1.79ish iirc. just know i did a couple high 1.7 in my 1990, it was 2750-2800 lbs with me and always had crap tires. it had rear lsd this car will be 2200-2300 with me, i would think the light weight should help a great deal! and i will have rear spool welded center diff front lsd i just want epic lauches, cause look at this thing! so pathetic!!! and im planning on still running the pizza cutter winter tires |
Author: | pimpy rider [ Sat Oct 03, 2015 2:47 pm ] |
Post subject: | Re: 1980 4g63t swap -now awd too |
judging by the weight of the rear i took out, (60 lbs) i can guess the final weight in the 2000lb even range. probably around 2050 but then i can always do a bunch of little hacks to get close to 2000 thats the main goal |
Author: | CaptainTonus [ Sat Oct 03, 2015 3:20 pm ] |
Holy sheeeeit. What rear-end are you using? This thing is going to be the ultimate death trap |
Author: | pimpy rider [ Sat Oct 03, 2015 5:25 pm ] |
it is the same rear that was in my 93 its a toyota 6.7" rear with 3.9 ratio. its open but i do have a spool i could put in it, lsd are hard to come by for this diff the advantage of using this diff over ford 8.8 is just weight. its a lot lighter and still plenty strong for under 400 hp ultimate deathtap? i like it, sounds manly ive just been calling it the ultimate sleeper. |
Author: | pimpy rider [ Sat Oct 17, 2015 6:37 pm ] |
[URL=http://smg.photobucket.com/user/pimpy_r ... 6.jpg.html][/URL awd trans in, work ahead of me to make it happen, have to modify/redo all my engine mounts super excited for the end result tho im obsessed with this thing right now 100% |
Page 3 of 4 | All times are UTC-05:00 |
