It is currently Sun Oct 19, 2025 8:33 pm
Post new topic  Reply to topic  [ 100 posts ]  Go to page 1 2 3 4 57 Next
PostPosted: Thu Jun 12, 2014 9:14 pm
I have been working on my car lately and thought I would start a build on it bc I have big plans for it in the future. So far I have done:
4g spindle swap
4g shifter base w/ 1g dsm arm mod
Strut top mount
Cv axles
f5m21 from 4g mirage
4g37 tb port matched intake
4g37 ecu
4g37 injectors (12/9)
hacked air can mod
Gt front sway bar (elantra)
Sway bar end links
Trans axle seals
oil pan gasket
94 Mitsubishi Mirage "4dr"
PostPosted: Thu Jun 19, 2014 6:21 pm
PostPosted: Thu Jun 19, 2014 6:26 pm
Reman from advance already rusty should have painted it
PostPosted: Thu Jun 19, 2014 6:28 pm
In the process of cleaning transmission
more of it cleaner coming soon
PostPosted: Thu Jun 19, 2014 6:39 pm
PostPosted: Thu Jun 19, 2014 9:03 pm
I like it. Any plans for a turbo swap?
PostPosted: Thu Jun 19, 2014 9:25 pm
My plans for this car is to keep it as simple and reliable as possible. Im not sure if I want to build a 4g15 to last or do a 4g63 or 4g64 swap all n/a possibly nos for that insta boost. I like performance but im bigger on gas mileage and want to get around 40 mpg. I would like to track down the 1.5 mvv setup but probably a long lost dream.
PostPosted: Fri Jun 20, 2014 5:21 am
Did you add the SUN CHASER decals or are they original? Never seen them before.
PostPosted: Fri Jun 20, 2014 6:55 am
Did you swap the rear drums too, or are you running different bolt patterns front/back?
Thom
PostPosted: Fri Jun 20, 2014 3:38 pm
I have done some research and found nothing on the logo, I bought it this way. I always wondered if the sunroof and decal was stock or not.
my best explination or guess is it was part of an RV or Boat combo to match but I love it and will get it redone
PostPosted: Fri Jun 20, 2014 3:40 pm
I havent swapped the rear yet still on 4x114.3 and dont want to get junkyard rear drum swap from 95 mirage so ill just wait to do 89mirageman rear disk swap to get it to 4x100 all around
PostPosted: Fri Jun 20, 2014 4:04 pm
Transmission before I started
cleaner transmission
PostPosted: Fri Jun 20, 2014 4:09 pm
Shifter disassembly
strut top mount
PostPosted: Fri Jun 20, 2014 6:58 pm
Did you order strut tops yet? I have a pair that have a couple thousand miles on them and are in good shape, they were new when they went on.
PostPosted: Sat Jun 21, 2014 7:21 pm
Yea I got new ones on I'm good thanks
