Little Bird http://4g61t.org/forum/viewtopic.php?f=64&t=38417 |
Page 4 of 8 |
Author: | thomcasey [ Wed Feb 26, 2014 12:18 pm ] |
Post subject: | Re: Little Bird |
Thanks for the info. Yea, it may be stock once again (except for the colt GT front brakes) it is still truckin along. I am very happy that you used the adapter plugs instead of hacking into the stock wiring. Made my swap much easier. The black colt should be on the road for many years since the motor is new. I picked up a pristine 1" MC from a Dodge Stealth for the yellow colt so these twin piston calipers should be much happier. |
Author: | thomcasey [ Mon Mar 10, 2014 7:47 am ] |
Got the car ready to go on Saturday morning. Was bleeding the clutch and WHAM!! Clutch fork broke. So, out came the axles and transmission again. THEN, the taller bolt hole for the tranny mount cracked off. So, had to put the non-lsd tranny in to get this up and running. Fortunately I have a bad f5m33 sitting in the back yard that I can steal the case from. Guess I can make it look purdy at the same time before installation. After the transmission fiasco I installed the battery and tried to start the car, click-click. Tried my battery from the Summit wagon, click-click. Mind you, both of these were fully charged a month ago and have been in the house. Not sure if the super cold temps we had up till February killed the batteries or what, but I tossed them on the charger again to see if they are ok. Otherwise I guess it is a trip to the parts store for a new one. But will be good to get it on the road and boostin' tonight. |
Author: | thomcasey [ Fri Mar 14, 2014 9:07 am ] |
She is a runner!!! http://youtu.be/ed2hftOMywA |
Author: | thomcasey [ Sat Mar 15, 2014 7:57 pm ] |
Thought we would snap some pics of the final product. Installed some new gauges in the center console and gave her a bath. |
Author: | quikgt [ Sat Mar 15, 2014 10:58 pm ] |
Looking good! Does the tach work? |
Author: | thomcasey [ Sun Mar 16, 2014 6:51 am ] |
Yes, the tach works. Only thing that doesn't work is the ac, because it has been pulled. |
Author: | cheaptalon [ Sun Mar 16, 2014 12:31 pm ] |
Looks good. Dat front camber doe. A red stripe down the molding would break up all the yellow too. |
Author: | thomcasey [ Sun Mar 16, 2014 7:10 pm ] |
That is just a weird effect from the camera. Camber is dead on. I had to go out and look after I took the pic to make sure |
Author: | thomcasey [ Sun Apr 13, 2014 4:44 pm ] |
The alternator died on Thursday night. So, I ordered a new ACDelco alternator for the 93-99 saturn. It was only $85 shipped from amazon with sunday delivery! I've never had an issuewith the gm alternators. Hope this one is the same. |
Author: | whe3ls [ Sun Apr 13, 2014 4:50 pm ] |
my alt is form a 94-97 1.9. if it came off a 1.9 it should be the same |
Author: | thomcasey [ Mon Apr 14, 2014 6:16 am ] |
I got it installed yesterday. I hated grinding on such a new, pristine part, but you gotta do what you gotta do. Of course the wiring for my Colt is a bit different. Colts have a RED large wire and a white small wire for the alternator vs the 1g DSM large YELLOW and small BLACK. Plus, the plug I got off the saturn at PAP had a striped wire to F pin and solid to L (which is opposite of what I have seen in writeups). I just ignored colors and went with the instructions and now I can turn on my turn signals without the tach bouncing. I also swapped out my throttle-body. I got tired of the 2300rpm cold start, sticky throttle plate and bad ISC. |
Author: | 89Mirageman [ Wed Apr 16, 2014 9:38 pm ] |
Pics of the new alternator installed? |
Author: | aaronsbig16g [ Thu Apr 17, 2014 7:51 pm ] |
Good stuff. |
Page 4 of 8 | All times are UTC-05:00 |
