It is currently Sun Apr 28, 2024 7:13 am
Post new topic  Reply to topic  [ 93 posts ]  Go to page Previous 1 2 3 4 57 Next
 Post subject: Re: 4 years later
PostPosted: Sun Dec 22, 2013 4:06 am
Nice work! I approve of 3G sedans and yours looks nice and clean! Can't believe this sat outside for years..... :drinkers:
I like the US lower dashes. They look nicer and less cheap than the Canadian ones here. I've never experienced those funky seatbelts though. All the C/DSMs here have regular pull to clip seat belts.
thanks man :drinkers: yea the lower part of he dash is not the problem it is the top that is a big piece of shit i have a big ass crack in it if i take it out i thing it will split into two pieces. i wish i could find a clean one.
08 silverado max
91 Eagle Summit 4g63t swapped
PostPosted: Mon Dec 23, 2013 8:53 am
Good progress, looks pretty clean and since I'm fan of the 5 spoke wheels I like them too but yeah always check the weight on them...
PostPosted: Tue Dec 24, 2013 3:20 am
thanks man. :drinkers:
08 silverado max
PostPosted: Wed Jan 01, 2014 10:53 pm
well today i started cleaning the bay and painted the lower part of the core support i still have some more cleaning and i am thinking about repainting the hole bay.
08 silverado max
PostPosted: Mon Jan 20, 2014 5:19 am
That is a CLEAN sedan, ill be up in Washington in under a year, cant wait to meet up with fellow CSM'ers.
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Tue Feb 18, 2014 1:33 am
thanks man. what part of WA you moving to?
small update order a hole bunch of parts Saturday so as soon as they get here i am hoping it get back together fast because i am itching to drive this thing. but you no the saying good things come to those who wait. lol :drinkers:
08 silverado max
PostPosted: Tue Feb 18, 2014 3:43 am
to the wet rainy part lol.. jk.
PostPosted: Tue Feb 18, 2014 4:24 am
lol we have 2 parts to WA the wet rainy part (western WA) and the snowy cold part (eastern WA)
08 silverado max
PostPosted: Tue Feb 18, 2014 9:00 am
Nice, but would you mind telling us the list of said parts? Or is it a secret :snky: haha
PostPosted: Tue Feb 18, 2014 11:25 pm
got this stuff from extreme PSI
MIT-MN163112OEM Oil Filler Cap : Mitsubishi Lancer EVO VIII & IX
PSI-BSRK Balance Shaft Eliminator Kit : Mitsubishi Eclipse 90-99
PSI-1GCLUTCHLINE Extreme PSI Complete Clutch Line (Slave to Master Cyl.): Mitsubishi Eclipse 90-94
TPL-LIFMI6-16 Topline Revised Lifters: Mitsubishi Eclipse 90-99
MIT-MD372348 OEM Valve Cover "Half-Moon" Seal: Mitsubishi Eclipse 90-99
PSI-VCBK Extreme PSI DSM 4G63T Stainless Steel Valve Cover Bolt Set
PSI-1GGSK Extreme PSI Heat Barrier Intake Manifold Gasket : Mitsubishi Eclipse 90-94
FEL-OS30460A Fel-Pro Oil Pan Gasket : 6 Bolt
MIT-MD189460 OEM J Pipe Gasket : Mitsubishi Eclipse 90-94
MIT-MD127058 OEM Oil Dipstick OEM : Mitsubishi Eclipse 90-94
MIT-MR497720x2 OEM Turbo Oil Return Line Washer for Oil Pan (2x): Mitsubishi
MIT-MD040332 OEM Rear Main Seal Separator: Mitsubishi Eclipse 90-94
PSI-7CMGSK 7CM Turbo to Manifold Gasket : Mitsubishi Eclipse 90-99
MIT-MD372536 OEM Camshaft Oil Seal : Mitsubishi Eclipse 90-99
MIT-MD183808 OEM Composite Head Gasket : Mitsubishi Eclipse 90-99
MIT-MD343563 OEM Front Main(crankshaft) Seal : Mitsubishi Eclipse 90-99
MIT-MD075834 OEM Mitsubishi Oil Dip Stick Tube O-Ring
MIT-MD149370 OEM Oil Filter Bracket Gasket: Mitsubishi Eclipse 6 Bolt
MIT-MD149393 OEM Oil Pump Front Cover Gasket : Mitsubishi Eclipse 6 Bolt
MIT-MD365697 OEM Oil Pump Shaft Seal : Mitsubishi Eclipse 90-99
MIT-MR258477 OEM Oil Return Line Gasket : Mitsubishi Eclipse 90-99
MIT-MD183240 OEM Oil Strainer Gasket: Mitsubishi Eclipse 90-99
MIT-MD125939/MD125940 OEM Valve Cover Gasket Set : Mitsubishi Eclipse 90-99
MIT-MD169859 OEM Water Pump Gasket : Mitsubishi Eclipse 90-94
MIT-MD030764 OEM Water Pump O-Ring : Mitsubishi Eclipse 90-99
MIT-MD619648 OEM Cam Angle Sensor O-Ring : Mitsubishi Eclipse 90-99
MIT-MD145038 OEM Thermostat Housing Gasket : Mitsubishi Eclipse 90-94
MIT-MD343564 OEM Rear Main Seal : Mitsubishi Eclipse 6-Bolt
MIT-MD183243 OEM Rear Main Gasket : Mitsubishi Eclipse 90-94
MIT-MD128107 OEM Crankshaft Sprocket Spacer (for Balance Shaft Removal): Mitsubishi Eclipse 90-99
JM-1G-BATKIT-00 JM Fab PC680 Small Battery Kit : Mitsubishi Eclipse 90-94
then i got this from summit racing
3 Motor Mount, Polyurethane, Red,13-501
1 Motor Mount, Polyurethane, Red,13-506
1 pack of Wheel Studs, Press-In, 12mm x 1.5 Right Hand Thread, Mitsubishi, EVO III, Set of 5 and buying the other 4 from a friend that got 4 packs for his mirage so he has some left over.
i am taking my cams to delta tomorrow and they are doing a HKS 272 grind on them and am also thinking of buying some HKS came gears.
08 silverado max
PostPosted: Wed Feb 19, 2014 10:03 pm
Well box 1 of 3 showed up today
08 silverado max
PostPosted: Wed Feb 19, 2014 10:52 pm
Return the oil pan gasket.
There is only sealant used by the factory ... and for a good reason.
Grey RTV by Permatex is the bomb in this regard.
Or Yamabond, ToyotaBond, HondaBond, Delco Engine Sealant (surprise!!the same grey stuff as in the Permatex bottle but drier and half the size for twice the cost) or any GOOD RTV for oil pans/engines. Don't buy stuff that's good for windows ... don't get me started, as some shops supply this stuff to auto repair facilities ... :rolleyes:
PostPosted: Wed Feb 19, 2014 11:07 pm
will do i was debating on getting it or not. i will end up using fuji bond just because i have a lot of it from when my roommate rebuilt his sti.lol
thanks for the heads up :drinkers:
08 silverado max
PostPosted: Tue Feb 25, 2014 5:17 pm
well another box showed up today now i have what i need to start putting the motor back together.
08 silverado max
PostPosted: Sun Mar 02, 2014 2:52 am
picked up some wheels today what you guys think?
08 silverado max
Users browsing this forum: No registered users and 116 guests
