It is currently Sun Apr 28, 2024 10:56 am
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Build #2- 89 GT AWD
PostPosted: Wed Mar 06, 2013 10:42 pm
More stuff done, though it doesn't look like much. I got the end caps pretty much done on both sides, only thing left to do are the bottom welds and then clean them up a little.
And that's where we are at for tonight. It's surprising how much time you have to spend measuring, cutting and tweaking each piece to weld in. I'm going to do my best to have the rearend mounted in before the end of weekend. We will see.
PostPosted: Thu Mar 07, 2013 7:57 pm
Rear section is all welded in now. I got the subframe mounted in to check everything out and start with the front mounting points. I'm very happy with where the wheels are sitting and how it fits.
PostPosted: Thu Mar 07, 2013 8:55 pm
Looks sick
PostPosted: Thu Mar 07, 2013 9:26 pm
Is it just me, drivers rear tire appears to be a shorter gap to the fender in front of it. With an exact point, matched on both sides, do they line up perfectly front to back as the same dimensions? This I am sure you have been trying to perfect the entire time you setup the rear end, just felt like asking your process. This sort of stuff is always neat to hear about.
PostPosted: Fri Mar 08, 2013 12:22 am
Good eye! Yes it looks like it is closer but that is because the tire rubbed on the wheel well lip and pulled it out so it looks like the gap is closer but I made sure to measure everything multiple times before tacking and then remeasured before welding everything in for good.
PostPosted: Wed Mar 13, 2013 11:41 pm
Small update, had drill over the weekend so no work on the project. I got the front mounting points half welded in today. I'll get it finished up and some pictures up tomorrow most likely.
PostPosted: Thu Mar 14, 2013 7:32 pm
Rear subframe mounts are done finally. That is easily the most stressful part of the awd swap. :axe:
Stuff left to fabricate-
*Driveshaft mounts
*rear strut mounts/wheel wells
*front and rear motor mounts
Gotta get the awd transmission and transfer case in and then start on the driveshaft mounts. Slowly but surely this thing is coming back together.
PostPosted: Thu Mar 21, 2013 7:27 pm
Working on the getting the awd transmission in and the driveshaft mounts done now.
PostPosted: Thu Mar 21, 2013 8:41 pm
This thing is moving right along, I agree on the rear subframe mounts.
PostPosted: Thu Mar 21, 2013 11:12 pm
This is exactly where my swap stopped almost two years ago. :cry: But she regained new life and is on it's way to 2.4 auto glory! Now hurry and finish So you can do mine also! :P
PostPosted: Fri Mar 22, 2013 9:43 pm
I don't travel. :lol:
Little more to update, busy day. Got the motor and transmission out of the talon, and everything apart. The motor and trans in the mirage are pretty much ready to be dropped out, just have to get the axle nuts off. PITA... Doesn't seem like I got much done today but o well.
My driveway is looking like a dsm/csm graveyard. :oops:
Poly mounts all installed
PostPosted: Sun Mar 24, 2013 8:57 pm
More stuff done over this weekend. I got the flywheel and starter plate swapped over and the awd transmission bolted on and then back into the engine bay.
Made a new discovery today, a 90 awd transmission requires some modification to work with the mirage mounts. I had to remove a decent size piece of aluminum from the case. I'm not even sure why the case is made this way, 91-94 don't have this problem. But I got it to work.
I also modified the transmission shift arms so I can use the stock shifter and cables. The mirage trans and 90 awd trans have essentially the same arms but are just stamped differently. So I just heat up and bent the arm into the correct shape.
I also spaced the bracket out about an inch to get the cables aligned well.
I'm thinking about doing the front mount like this. Just extending the front metal mount and mounting the front poly mount to the radiator support. Any input on that idea? I can't think of any real draw backs but maybe someone else can.
PostPosted: Thu Mar 28, 2013 7:59 pm
Moved to the back and started in on the driveshaft carrier bearing mounts.
Started out by drilling out the spot welds on the stock talon pieces. I got the driveshaft's front shaft removed from the back 2 and started mocking it up. Did a little cutting and bending and smacking with a BFH and got it fitting really nice. I wish I would have done it this way the first time with my swap. :lol:
Not sure why my phone is making the pictures come out so bright. I have it about halfway welded in. I just need to mock up a couple pieces to finish it off.
PostPosted: Fri Mar 29, 2013 4:53 am
Are you using a 110 welder with flux core wire? I'm not poking fun, just looking out for your safety
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Mar 29, 2013 11:49 am
It's a a 90 welder with flux yes. Gotta work with what I have. Are you talking about the fumes?
Users browsing this forum: No registered users and 107 guests
