4g15 to 4g63(SOHC) http://4g61t.org/forum/viewtopic.php?f=64&t=35754 |
Author: | ChrisYordanov [ Wed Dec 14, 2011 3:42 pm ] |
Post subject: | 4g15 to 4g63(SOHC) |
Hi Friends.Can I swap 4g63(SOHC 16V) from Galant into my Mirage(Swift-1988 ),or is it easier to swap 4g63(SOHC 8V) ? The 8V configuration looks like mine (4g15) 8V --> http://www.google.bg/imgres?q=4g63+sohc ... 9,r:12,s:0 16V ---> http://www.google.bg/imgres?q=4g63+sohc ... 9,r:18,s:0 Thanks ![]() |
Author: | CSM Shaun [ Wed Dec 14, 2011 7:59 pm ] |
Post subject: | Re: 4g15 to 4g63(SOHC) |
It depends on what sensors you can make work. |
Author: | Mirage90 [ Sat Jan 14, 2012 12:23 pm ] |
I thought the 8v 2.4 have the same wiring harness as the 4g15? If so all you would need is, 2.0 tranny "with mount" Custom mounts for the front and the back of the block. Something like this http://www.4g61t.org/forum/viewtopic.php?f=64&t=31752 And the timing bet mount from 95 Elantra uweenukr dad's swap is 16v though ![]() I am curious about this also. |
