It is currently Sun Apr 28, 2024 12:53 pm
Post new topic  Reply to topic  [ 268 posts ]  Go to page Previous 14 5 6 7 818 Next
PostPosted: Wed Apr 24, 2013 11:13 pm
The colt should go faster for sure running those big stickys!
PostPosted: Mon Apr 29, 2013 9:24 pm
Well, I will be piloting the colt. I do weigh 30# or so more than Warren, however the wheels alone will drop 50#of rotating mass so I should be good. There is no way I will out MPH the evo, but I will do my damndest to beat it to the finish line. :partyman:
PostPosted: Tue Apr 30, 2013 9:09 pm
Should be an awesome race for sure! Better get some videos!
PostPosted: Mon Aug 05, 2013 10:56 am
My brother and I took the car to the track this past weekend . here is what he had to say
"Finally got it out to the track over the weekend. Still have a couple things to address. We are on 10 year old dryrotted tires and a total of 43lbs on each corner, the alternator is dying which was/has been messing with our fueling in the tune, and the rear struts are gone.
All that being said, we started off with a all the timing pulled from the car and the boost down a bit for the pulls at Lapeer.
First pull, 35psi in eash tire and no 2 step it ran 12.5@114 with a 2.0 60ft.
Took air out of the tires added a little boost and some timing and ran a 12.2 @117 with a 1.9 60'
Added a little more timing and finished the day with a 12.2 @119 with a 1.9 60'
Was only able to get 3 runs in, on the last run I missed 4th and hot lapped it to get a 3rd pass. The run I missed fourth would have been a little better than the hot lapped pass, but oh well.
The car is still very conservative on timng and hopfully we will have a little more time to address the wheel tire combo and the tune. The struts will be done tuesday and the alternator as well.
I know there is video out there, but I don't have any.
Also,
if anyone has a light 15" or 16" 5X114 wheel out there, we are looking and let us know.
2 weeks till the shootout "
yeah budyyyyyyy :lol: :lol: :lol: shootout is going to be awesome. Think they will allow the car to run in DSA
Warren
PostPosted: Mon Aug 05, 2013 9:11 pm
Nice shake down passes! Can't wait to see it at shootout and the only classes you can run are quick 16 and bracket :-? I would love to see a swapped heads up class.
PostPosted: Tue Aug 06, 2013 8:10 am
Yeah, it will be entered into B1.
Got a wheel/tire combo donated for the shootout. 37lb each corner and only all seasons, but thats better than what is on there.
Alternator and rear struts will be going on this week and should be able to tune a bit more this weekend.
The shootout clock is ticking :supz:
PostPosted: Mon Aug 19, 2013 9:15 am
The 2013 dsm/evo/gtr shootout is finally over... The long sleepless nights, the hustling to get parts in , while maintaining career jobs and work schedules was starting to wear on the team.
It was no different for the colt. A short summary of what transpired from the events in lapeer.
What we thought was a fuel issue, ended up being a fuel filter that crushed itself from the high fuel pressures that the two 255 walboro pumps were pushing. So I wasted $250 on some new pumps and had them replaced.
Next the rear struts were in poor shape, so jeremy replaced those with some off the shelf autozone specials.
Thanks to andy he donated some decent tires and wheels for the shootout, that dropped the weight down to 37 ibs a corner, from the 42 ibs per corner.
Then there was the whole tuning part of the car, jeremy and i hammered it out on friday morning ( just prior to leaving for the shootout). The car for some reason, has very inconsistent boost pressure, i.e it goes from a spike of 31psi down to gate pressure , so we chased, boost leak tests, to placing a bigger intake to feed the turbo amongst other things. So pretty typical for the shootout preparations, run around with your head cut off .
At the shootout, 1st pass out of the gate, jeremy hits an 11.94 @ 116 I think .. Our crew was absolutely over joyed, with how well this car takes to timing. and boost , this was with a 1.9 sixty foot as well. As the day progressed, he ran a couple of low 12s, and then finally finished off the event with a 11.8x @ 119. We are pretty happy with this little car, as it came to do work. More importantly, it represents our team quite well, as it has been worked on by every single person in our club. and that I feel is more important than anything else, a bunch of enthusiasts having a good time and enjoying our hobby.
The only shot I have of the car, and a poor one at that
Thanks for reading- stay tuned for more.
Warren
PostPosted: Mon Aug 19, 2013 8:46 pm
Congrats guys! Glad to see all your hard work pay off. It was good seeing you guys again.
PostPosted: Tue Aug 27, 2013 10:19 pm
It was good seeing you guys Aaron. I hope that nut on the stud was easy enough to get off for a carrier bearing nut.
The colt has done all we asked of it on a tiny 18g turbo. We will try to get a few more passes this year, but with the way it bounced off the line, until we redo the suspension, we may be stuck.
Bigger turbo will cure all :supz:
PostPosted: Mon Sep 09, 2013 8:24 am
I had to go and support the opening of onondaga dragway Yesterday. It was an absolute blast.
after getting many strange looks, a bunch of laughs .. I was able to stage against a beautiful big tire , hemi muscle car. As I left the line, the car hooked well, but I came out of the grove a little, I countered steered the colt and smashed the gas with a well placed 1st to 2nd gear shift. I looked out of my side window and much to my amazement I didn't see the muscle car :)
As I got back to the area, the strange looks turned into " what the hell you got in that thing"... being the only 4 banger out there it was definitely quite the spectacle. On that pass it ran 8.3 @ 94 mph which is a couple mph more than at the shootout.
Next pass was against my good friend AJ in his bad ass Maurader. He caught me sleeping at the tree and consequently passed the line first. When we went to get the slips I was in shock at the car went 8.02@95.6 holy shit that was a great pass, and I am certain, that with numbers like that , the colt would have been in the 11.60s
http://www.youtube.com/watch?v=DQ8LRbMtnI8
Ran a couple more times, but I couldn't better that 8.0 pass...
Definitely had a great time at Onondaga dragway.. More to come
Warren
PostPosted: Mon Sep 09, 2013 10:43 am
So glad to see this car up and running and making good passes. I remember this car's build thread from way back in the day when Adam had it. I just remember it being so clean.
PostPosted: Mon Sep 09, 2013 11:06 am
Yup adam did some decent work. Our team was able to finish the car, as it still required many things, like wiring, brakes, fuel, redo rear suspension, clutch assembly stuff etc. So it has definitely come a long way :)
I have a 3065 for the car that requires a rebuild, so Hopefully I can get that on there. However I am sure this thing will be in the 11.50s soon, since it picks up almost 28 mph on the back half of the track :)
Warren
PostPosted: Mon Sep 09, 2013 11:14 am
Do you still own all the cars in your sig? If so how on earth do you manage to keep three race cars going?
PostPosted: Mon Sep 09, 2013 11:25 am
Yes I own them all still, It has been very difficult to keep them all together to be honest and the worst of them all is the evo
The evo in particular has plagued me with engine failures. It is very demanding, especially on the level of time that it requires to try and be competitive. This year along I have been fighting an issue where it keeps chewing bearings at the big end of the track. --
Warren
PostPosted: Wed Sep 11, 2013 10:16 pm
Glad to hear you made some good hits in the colt! Congrats!
Users browsing this forum: No registered users and 133 guests
