whe3ls's hyundai http://4g61t.org/forum/viewtopic.php?f=64&t=33426 |
Page 14 of 19 |
Author: | whe3ls [ Sun Jun 09, 2013 9:27 pm ] |
Post subject: | Re: whe3ls's hyundai |
here is a video http://www.youtube.com/watch?feature=pl ... 693mXm1_LA and a bought a new dd. its a 93-94 SHO. it needs a little work. it needs rear struts brakes front fender and a front bumper |
Author: | xxNocturnalxx [ Mon Jun 10, 2013 12:42 am ] |
She's alive!! Good work man, and get that wastegate out of the radiator |
Author: | whe3ls [ Mon Jun 10, 2013 8:58 am ] |
I haven't made the dump tube or the exhaust yet. I'm having a issue with the alt grounding when the power wire is bolted up, almost burned the car down. |
Author: | whe3ls [ Fri Jun 14, 2013 9:49 pm ] |
Another video. Right before this I blew out the oil filter seal https://www.youtube.com/watch?v=xtVc-qW ... ata_player |
Author: | slowdsm [ Fri Jun 14, 2013 11:11 pm ] |
in gear start FTW lol Steve |
Author: | whe3ls [ Sat Jun 15, 2013 8:56 am ] |
I forgot it was in drive when I started it. Oopps |
Author: | whe3ls [ Tue Jun 25, 2013 7:45 pm ] |
https://www.youtube.com/watch?v=eErzLag ... ata_player |
Author: | xxNocturnalxx [ Tue Jun 25, 2013 8:49 pm ] |
Braaap psssssssshhhhhhhhheeeeeeeeww |
Author: | whe3ls [ Thu Jun 27, 2013 8:46 am ] |
engine bay shot |
Author: | whe3ls [ Fri Jul 19, 2013 6:29 pm ] |
been working on some wiring for the shift box. i need to order some more supplies. shifter bottons forced four gear display next im going to finish my 1g dsm to evo patch harness |
Author: | whe3ls [ Thu Jul 25, 2013 3:22 pm ] |
picked up a radiator fan, i still need to get a awd auto intermediate shaft and axle and expo knuckles and brakes. then i can save up for a meth kit. im also working on the patch harness. what a pia.... |
Author: | whe3ls [ Fri Jul 26, 2013 7:24 pm ] |
getting closer to getting my patch harness done. about 8 more pins to finish. and then adding the evo connectors onto the other side. |
Author: | Broke4speed [ Fri Jul 26, 2013 8:19 pm ] |
The Evo ecu swap is awesome . Check out dsmecu.com for waaaaaaaaaaaay better info on that swap than the long thread on DSM tuners. Did you get your ecu yet? |
Author: | whe3ls [ Fri Jul 26, 2013 8:27 pm ] |
i havent gotten the ecu yet. its still my list of parts to get. going to get everything shorted first |
Author: | Broke4speed [ Fri Jul 26, 2013 10:07 pm ] |
If you're not dead-set on ecu-controlled boost, then the 2001-2003 Eclipse M/T and 2002-2004 Lancer M/T ecus will work fine with the Evo 8 rom file. I have both, and each one runs my car exactly the same . You can also use the 2001-2004 A/T ecus, but there's a different wiring setup required, and a modded evo 8 rom is needed. My ecu of choice is a 2003 Lancer A/T, so I've got the file . Also...it's not a well-known detail, but we discovered that you can use a $10 Ebay VAG-COM cable to flash the M/T ecus with Evoscan (there's a freebie flashing utility for the E8 and E9 cars). No need to splurge on any expensive cable. I've got a real cable, and a VAG-COM, and they both work the same. |
Page 14 of 19 | All times are UTC-05:00 |
