It is currently Sat Jan 18, 2020 12:27 pm
Post new topic  Reply to topic  [ 138 posts ]  Go to page Previous 16 7 8 9 10 Next
PostPosted: Wed Apr 09, 2014 9:01 pm
Well I'm back from deployment and its time to start rebuilding my engine. I overheated it really bad weeks before I left and had no time or patience to deal with it any further. what I found...
1. Head was beautifully clean inside thanks to awesome maintenance.
2. Head was warped just over .005" which is huge especially using a MLs gasket.
3. Block is straight as an arrow but has surface rust and cylinders need a bore to be cleaned.
4. #1 piston has a big dent above the compression ring from god knows what, and the #1 piston between compression rings was cracked.
5. bearing surfaces look great and show no sign of oil starvation, warping etc.
6. crank is smooth as a baby's ass
The Good.
1. block is getting bored, magna fluxed and hot tanked hopefully next week
2. crank is getting balanced and polished for piece of mind
3. the New $70 head is straight just dirty. getting it decked just to remove light scratching
4. going to modify the oil passages on the block and head to improve oil flow
5. Work has already begun... LETS BUILD THIS B**CH
The carnage
91 Talon TSi AWD- SOLD
91 Mirage 4dr 4G63T -Daily
facebook.com/modicausmc
PostPosted: Tue May 13, 2014 10:34 pm
Any chance you could take a straight-on shot of the back so I could see how the spoiler fits the body width-wise?
PostPosted: Tue May 13, 2014 10:43 pm
I can help here
PostPosted: Tue May 13, 2014 11:21 pm
I <3 you, Tony. I almost looked through your albums, but then instantly forgot what I was doing.
PostPosted: Wed May 14, 2014 6:05 pm
The spoiler I got from Skap is different from the higher-rise lancer spoiler in Tony's picture. It also doesn't fit quite perfectly. I'm thinking it's for the liftback lancer and not the 4 door version.
Either way, if you have a 91-92 trunk it's going to require some cutting and modification. the 89-90 trunks have the indent for the spoiler bolt holes which is still a little bit off from where the holes need to be drilled. The 91+ trunks must be from a different mold since they were built in the US vs. Japan.
90 Mirage LIL EVO 940awhp
14 Audi R8 V10
07 LS460L, 01 LS430
13 Tundra TRD S/C, 96 T100
96 Land Cruiser GT35R
PostPosted: Wed May 14, 2014 6:58 pm
That ass
PostPosted: Wed May 14, 2014 7:09 pm
Jason, thanks for the heads up. The spoiler on this car is from a gvr4. I asked bowdown about it a while back. I'm actually looking into a different one from another make that's mor aggressive but can't decide if I like the rear end better naked.
PostPosted: Wed May 14, 2014 7:11 pm
Ahh ok, I thought it looked familiar.
I wonder what spoiler this is then
14 Audi R8 V10
07 LS460L, 01 LS430
PostPosted: Wed Sep 17, 2014 3:07 am
It's been a while since I have updated since my computer took a crap. Big things have been happening in the time trust me and I'll update pics when the computer is fixed, I've been keeping on project, destroying all my clothes and eating PB&J and ramen making this build happen... SOOOO HERE IS HOW SHE SITS
New engine:
- 4G63 2.0L
- crank polished and manga fluxed
- block cleaned and honed
- Manley Turbo tuff I Beam rods
- WISECO forged .040 over 8.3:1
- ACL rod and Main bearings
- ARP Head, main and rod bolts
- Balance shaft delete w/ straight cut oil gears
- Oil clearances right in the middle of spec of rods and mains
HEAD 4G63 w/ stock cam gears:
- hand mirror polished combustion chambers
- ported and smoothed intake runners (slight port)
- pressure checked and decked
- head oil supply tear dropped and enlarged slightly
- polished stock 1G cams (Kelford cam gears soon)
- Crower springs, seats and retainers ( Kiggley beehives soon w/ cam upgrade)
- cleaned and inspected 1G rockers and 3G revised lifters
- VITON intake and exhaust seals
MISC:
- OEM block and head gasket set
- Evo 8 metal half moon seal
- rebuilt 1g throttle body
- Megan oil catch can
TURBO:
- Brand new FP 68HTA
- ARP EXHAUST studs
FUEL: 100% new!!
- 550cc Evo injectors (just for break in miles)
- 1650cc FIC Bluemax (after engine break In)
- Wally 255HP
- Brand new OEM fuel tank
- -6 E85 compliant reinforced fuel line (tank to engine and return)
- -6 feed and return fittings modded on hanger
- Fuellab fuel filter
- Fuellab FPR
EXHAUST:
- Megan 3" down pipe
- Evo 3 exhaust manifold
- 1g O2 housing
- 3" side exit custom exhaust exiting at rear driver side door
EXISTING MODS
- ECMlink V3 Lite
- SD AND 3 bar MAP
- FP 4" intake and 4"-2.5" reduced coupler
- K&N 9" air filter
- 1G Flywheel
- ACT 2600 w/ street disc
- F5M33 trans with a grinding 2nd gear
- Direzza DZ101 205/50/15 rear tires
- Direzza ZII 205/50/15 front tires
- 3G brake master cylinder- stainless braided brake lines and F/R disk brakes
- FMIC
CANT WAIT FOR FIRE IN TWO WEEKS!!! STAY TUNED
PostPosted: Wed Sep 17, 2014 1:00 pm
Looking awesome, im definitely excited for some pics and more updates.
94 Mitsubishi Mirage "4dr"
PostPosted: Wed Sep 17, 2014 2:13 pm
The Parts accumiliation before the build.
PostPosted: Tue Sep 23, 2014 10:36 pm
some new updates, the fuel tank and pump hanger are rusted BAD! Ordered a new OEM tank that just came, sanded down the rust on the hanger and am now modifying it for AN -6 feed and return lines. 20' of Gates -6 fuel hose came in also along with the Fuel lab FPR and filter. 3" 90* bend for the exhaust is here with a 2 bolt flange to mount the side exit exhaust. long working hours are haulting progress so im hoping for fire in 3 weeks now. Also got bored and mirror polished the stock intake manifold and sanded out the rough sides in the intake runners and ported the turbo hotside slightly. While I had her apart I cleaned the throttle body (it was black lol) and replaced the seals so no more idle surge (hopefully :o )
PostPosted: Thu Sep 25, 2014 4:30 pm
Just picked up some FIC Bluemax 1650cc for $300... gonna use the 550's for break in then thrown in the 1650's for a low boost (17psi) 91oct tune and a high boost 25psi E85 tune. :supz:
PostPosted: Sat Oct 11, 2014 5:12 am
What a PITA! 3 owners ago the guy tried to build a destroker 2.1L out of my G4CS. LONG story short, engines gotta get pulled apart because there's an 88mm crank and no 156mm rods so there is a 6mm gap from the pistons at TDC to the deck of the block. The machine shop Has my old 2.0 and is inspecting for whether I can hone or have to bore. As soon as I know Wiseco 9.0:1 non HD pistons will be ordered as well as the $250 worth of oil squirters and misc crap to get this one ready. Slight set back but my goals are set. Wally 255 and new modded -6AN pump hanger went In today, 3 hours to get it to seat in the tank but nice fit, fuel lines ran tomorrow and wiring cleaned up. Full attack mode on this beast! I need power!!
PostPosted: Tue Oct 14, 2014 8:14 pm
my fix for the 3G brake master line not matching up
Fuel fittings, 3g lifters and new ACT street disc
modding the fuel hanger
NEW OEM tank
